1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Newport controller ESP302
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Jong Woo Kim <Jong.Woo.Kim at asu.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 26 Oct 2022 03:55:05 +0000
There are no example IOCs for the ESP302 in motorNewport.
Here is an iocBoot directory for an ESP300, which uses serial, not Ethernet. You should be able to replace drvAsynSerialPortConfigure with drvAsynIPPortConfigure. You need to use port 5001.
https://github.com/CARS-UChicago/GSECARS-EPICS/tree/master/iocBoot/ioc13esp_test
I think the commands for the ESP302 should be the same as the ESP300.
Sent from my iPhone
On Oct 25, 2022, at 9:24 PM, Jong Woo Kim <Jong.Woo.Kim at asu.edu> wrote:
Dear Mark,
Which one is the right startup IOC file for it?
Best,
Jong
Sent: Tuesday, October 25, 2022 6:43 PM
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
I have used it and made improvements to the driver.
What would you like to know?
Sent from my iPhone
On Oct 25, 2022, at 7:47 PM, Jong Woo Kim via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hello!
Is there anybody who has experience with Newport ESP302 (TCP/IP) and EPICS IOC?
Best,
Jong
Newport controller ESP302 Jong Woo Kim via Tech-talk
Re: Newport controller ESP302 Mark Rivers via Tech-talk
Re: Newport controller ESP302 Jong Woo Kim via Tech-talk
Prev: Re: Newport controller ESP302 Jong Woo Kim via Tech-talk
Next: ADPlugin for average of images Letícia Garcez Capovilla via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 26 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
