1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: P4P usage for the pvget and pvput for the NTTable in Matlab
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Kim, Kuktae" <ktkim at slac.stanford.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 27 Oct 2022 16:16:58 -0400
Hi Kuktae,
On 10/25/22 19:29, Kim, Kuktae via Tech-talk wrote:
Hi all,
I am trying to use the P4P python module (https://mdavidsaver.github.io/p4p/index.html# <https://mdavidsaver.github.io/p4p/index.html#>) in Matlab for EPICS NTTable PVs.
Versions that I use:
*/Python: 3.8.13/*
*/P4P: 4.1.3/*
*/Matlab: 2020a/*
Wow, so matlab can call into cpython now?
This is news to me.
First, I tested pvget and pvput in linux terminal, then moved to python and Matlab for each step. It works without problem for the NTScalar and NTScalarArray types. But I don't know how to implement for NTTable type. I will put more information below.
You have found the NTTable helper, which doesn't actually
do that much wrt. the Type definition.
https://github.com/mdavidsaver/p4p/blob/5717342c2c1ddd74217298decab7ce52faa60006/src/p4p/nt/__init__.py#L157-L164
You can also use the NTTable wrapper when setting up the
client Context.  Which may or may not be helpful in your
application.
ctxt = p4p.client.thread.Context(nt={"epics:nt/NTTable:1.0": p4p.nt.NTTable})
With this, ctx.get() will implicitly call NTTable.unwrap()
*/In the Python command line, work fine; but pvget doesn't show a whole table./*
from p4p.client.thread import Context
MatP4P = Context('pva')
MatP4P.get('TEST:TBL')
Value(id:epics:nt/NTTable:1.0, Value(['device_1', 'device_2']))     # <== P4P doesn't show whole information such as in linux terminal
To avoid excessive console output, the repr() implementation for Value does not recurse.
You might investigate Value.tolist(), .todict(), or .tostr()
https://mdavidsaver.github.io/p4p/values.html#p4p.Value.tolist
*/In Matlab command line, pvput shows error message. Due to the colon operator.
MatP4P.put('TEST:TBL', {'value.name': ['test1', 'test2'], 'value.number': [10, 20]})
Warning: Colon operands must be real scalars.
Error using  :
For colon operator with char operands, first and last operands must be char.
This looks like a matlab syntax error.  Maybe this link is relevant?
https://www.mathworks.com/help/matlab/matlab_external/python-dict-variables.html
Re: P4P usage for the pvget and pvput for the NTTable in Matlab Kim, Kuktae via Tech-talk
Prev: RE: ADPlugin for average of images Mark Rivers via Tech-talk
Next: Re: P4P usage for the pvget and pvput for the NTTable in Matlab Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: P4P usage for the pvget and pvput for the NTTable in Matlab Kim, Kuktae via Tech-talk
ANJ, 27 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
