1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Missing DLL entry points in PV utils on windows-x64-mingw?
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Eloise de Castelnau <edecastelnau at radiabeam.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 28 Oct 2022 09:59:03 -0400
On 10/27/22 20:59, Eloise de Castelnau via Tech-talk wrote:
Hello –
I recently installed epics on my windows PC for the first time and am running IOC’s with asyn, stream, calc, and I’m able to use caget and caput for channel access without issue. However, running pvlist within msys causes it to just fail silently, and running the .exe returns these warnings – it seems like a few of the pvinfo/pvdata DLL’s don’t build correctly. The issue originally presented with base 7.0.4, and then I built fresh on 7.0.7 and saw the same issue. Has anyone ever had this issue on mingw? Transcription of one of the errors [ it opens a myriad of similar dialogs referencing missing entry points in pv****.dll files but I’ve just copied one of them since I don’t imagine the specific entry points are at issue] in case the image doesn’t carry through:
“pvlist.exe – Entry Point Not Found
The procedure entry point _/ZNSt7/__cxx1118basic_stringstreamlcSt11char_traitslcEsalcEEC1Ev could not be located in the dynamic link library C:\msys64\home\Eloise\base-7.0.7\bin\windows-x64-mingw\pvData.dll”
I don't use mingw (or windows) often, so I can't say for certain.
I suspect some kind of inconsistent/incomplete build.
Maybe your %PATH% includes older versions of pvlist and/or pvData.dll?
You could try running with a minimal %PATH% ?
Missing DLL entry points in PV utils on windows-x64-mingw? Eloise de Castelnau via Tech-talk
Prev: Re: Grabbing data from REST API Sean Leavey via Tech-talk
Next: RE: [EXTERNAL] Re: Grabbing data from REST API Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Missing DLL entry points in PV utils on windows-x64-mingw? Eloise de Castelnau via Tech-talk
Next: Grabbing data from REST API Sean Leavey via Tech-talk
ANJ, 28 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
