1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: menuScan
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Pierrick M Hanlet <hanlet at fnal.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 14 Nov 2022 20:06:18 +0000
Hi Pierrick,
I suspect the problem is that your application is including modbus.dbd rather than modbusSupport.dbd.
In January 2021 modbus.dbd was removed, and a new file modbusApp.dbd is built in the Makefile.  This should reduce confusion.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Pierrick M Hanlet via Tech-talk
Sent: Monday, November 14, 2022 1:59 PM
To: tech-talk at aps.anl.gov
Subject: menuScan
I'm having a similar problem to that in the thread "EPICS R3.15 and menuScan.dbd".
I'm using v7.0.5 on a scientific linux computer.  I have a custom version of menuScan.dbd
which we need at Fermilab and has been working for a while.  However, recently, I've
added modbus for some PLCs, and now I get build errors when creating my IOCs dbd file:
dbdExpand.pl: A different menu named 'menuScan' already exists
Context: menu(menuScan) in file '/usr/local/epics/Support/modbus/dbd/modbus.dbd'
  while reading 'modbus.dbd' to create 'pip2itVAC.dbd'
I don't have base.dbd in any of my modules, so it seems as though Andrew's suggestions
don't apply to my problem.
Cheers,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: menuScan Pierrick M Hanlet via Tech-talk
Prev: menuScan Pierrick M Hanlet via Tech-talk
Next: Re: menuScan Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
