1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: possible race condition in Newport XPS-Q8
From: "Pearson, Matthew via Tech-talk" <[email protected]>
Date: Fri, 18 Nov 2022 16:48:55 +0000
I don’t really work with these controllers anymore, but I looked into a problem on one of our beamlines yesterday involving a premature callback from a motor record move on one axis on a Newport XPS-Q8 controller, which I don’t recall seeing before.
The axis was requested to move using put_callback. The move() function in XPSAxis.cpp seemed to execute ok and the motorStatusDone parameter was set to zero (which was reflected in the motor record MSTA field). Then in the next poll of the controller we must have read the XPS axis group status to be ‘not moving’, because it immediately set motorStatusDone=1 and the callback completed. Then the motor started moving and completed the move normally.
So this seems like a race condition in the software on the XPS-Q8. We send a move command and then immediately read the status and it was incorrect. Has anyone seen this before on any flavor of XPS controller?
The server where this software is running is unusually heavily loaded, which may have exposed a race condition that has always been there.
Anyway, if anyone has seen this, have they tried using the ‘enableMovingMode’ shell function to change the way the ‘move done’ is reported? I suspect that might fix the issue as it waits for a response from the XPS ‘moveSocket_’ to determine ‘move done’, rather than polling the axis group status.
Cheers,
Matt
RE: possible race condition in Newport XPS-Q8 Mark Rivers via Tech-talk
Prev: Re: Phoebus Michael Davidsaver via Tech-talk
Next: RE: possible race condition in Newport XPS-Q8 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
