1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Possible to create aliases for record fields?
From: "Li, Ji via Tech-talk" <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 20 Dec 2022 19:11:05 +0000
Thank you Michael.
Best,
-Ji
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Tuesday, December 20, 2022 13:58
To: Li, Ji <liji at bnl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
On 12/20/22 10:49, Li, Ji via Tech-talk wrote:
> Hi,
> I'm trying to access record fields as PVs using alias command, such as:
> alias("det1.NELM", "det1:NELM")
> alias("det1.TSEN", "det1:TSEN")
> The IOC didn't report errors,
This lack of a warning/error is a bug.
> but apparently they all pointed to det1 as the change to det1 appeared on these aliases, and vice versa, and this was proved by dbla.
> If alias command is not the right choice, are there any ways to create aliases/dummy PVs for fields?
Field aliases are not currently possible.
Possible to create aliases for record fields? Li, Ji via Tech-talk
Re: Possible to create aliases for record fields? Michael Davidsaver via Tech-talk
Prev: Re: Possible to create aliases for record fields? Michael Davidsaver via Tech-talk
Next: Re: Possible to create aliases for record fields? Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 20 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
