1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Checking CPU and memory usage for an IOC
From: "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: Simon Rose <Simon.Rose at ess.eu>, EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 21 Dec 2022 05:55:57 +0000
All,
I was able to get iocStats working. However, there is a slight error in this document under the ao record section: https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/README_devIocStats
Shouldn't cpuScanRate be cpu_scan_rate?
Thank you,
Andy
cpuScanRate
Sent: Monday, December 12, 2022 5:58 PM
To: Simon Rose <Simon.Rose at ess.eu>; EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: RE: Checking CPU and memory usage for an IOC
Thank you Simon!
Sent: Monday, December 12, 2022 2:34 PM
To: Wang, Andrew <wang126 at llnl.gov>; EPICS tech-talk <tech-talk at aps.anl.gov>
Hi Andy –
There is the iocStats module that might do what you are looking for: https://github.com/epics-modules/iocStats.
In particular, there is a record that specifically monitors CPU usage: https://github.com/epics-modules/iocStats/blob/master/iocAdmin/Db/ioc.template#L130 (as well as one for memory usage).
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Wang, Andrew" <wang126 at llnl.gov>
Date: Monday, 12 December 2022 at 23:13
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: Checking CPU and memory usage for an IOC
All,
This is a very general question, but I was curious if people here have been able to monitor CPU and memory usage of a particular IOC as it ran. If so, what was the approach you took to do so?
Thank you,
Andy
Re: Checking CPU and memory usage for an IOC Andrew Johnson via Tech-talk
Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Re: Checking CPU and memory usage for an IOC Simon Rose via Tech-talk
RE: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Prev: Re: Possible to create aliases for record fields? Li, Ji via Tech-talk
Next: Re: Checking CPU and memory usage for an IOC Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
ANJ, 21 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
