1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Transform record behavior
From: Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 27 Dec 2022 08:55:48 +0000
I forgot to say that I had to change CLC fields also to CLCE-H from CLCA-D
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Tuesday, December 27, 2022 11:51 AM
To: tech-talk at aps.anl.gov
Subject: Transform record behavior
Hi
I am developing a coordinate motion system using the transform record but I am facing a weird behavior. The transform record is configured as:
1.       COPT: always
2.       INPA – D: Input links for the motors.
3.       CLCEH: corresponding kinematic equation.
4.       OUTE – H: Output links for soft records to set the current measure coordinate motion (Gap, center, etc.)
This is the working setup right now with both forward and reverse kinematics, previously I had the output links on OUTA to D and I had the whole coordinate system messed up with weird values. Why using OUTA to D in this case did not work?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
abdalla.ahmad at sesame.org.jo
www.sesame.org.jo
Transform record behavior Abdalla Ahmad via Tech-talk
Prev: Transform record behavior Abdalla Ahmad via Tech-talk
Next: Re: Possible to create aliases for record fields? Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 28 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
