1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Possible to create aliases for record fields?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Andrew Johnson <[email protected]>, "Hu, Yong" <[email protected]>, Zimoch Dirk <[email protected]>
Date: Tue, 3 Jan 2023 11:28:09 -0800
On 1/2/23 19:43, Andrew Johnson wrote:
On 1/2/23 3:53 PM, Hu, Yong via Tech-talk wrote:
Michael, we are talking about fields here. So “det1:NELM.RTYP” itself is not valid.
If "det1" is an IOC record, then "det1.RTYP" is definitely a PV name that the IOC will respond to. "RTYP" is a record attribute that the IOC adds to all record types, which returns the name of the record type. Some CA client applications (e.g. MEDM, capr.pl, CS-Studio's pvtree) query that attribute automatically for some/all of the channels they connect to, so a field alias such as the one suggested could result in the IOC seeing requests for that PV name.
Another (less important) use case is a script I sometimes use to avoid developing OPI screens remotely.
Michael's question is thus a valid one. For a simple/naive implementation of this feature the answer might be that the channel name “det1:NELM.RTYP” would time out, and such field aliases just wouldn't support the capr.pl or pvtree applications at all in that case. That might be acceptable,
I think it is desirable to continue to support remote database "crawling", although no necessarily with RTYP alone.  Which has obvious limitations in requiring a client to encode knowledge about record types.  An alternative which I occasionally think about is adding another pseudo field which GETs a description of the record type.  eg. as a string (.dbd or some json) or equivalent PVD structure.
but I would want to be shown that any implementation would not significantly increase the amount of work that the IOC's CA Search thread has to do.
Agreed.  In both the positive and especially the negative case.
Re: Possible to create aliases for record fields? Michael Davidsaver via Tech-talk
Re: Possible to create aliases for record fields? Hu, Yong via Tech-talk
Re: Possible to create aliases for record fields? Andrew Johnson via Tech-talk
Prev: Re: Possible to create aliases for record fields? Andrew Johnson via Tech-talk
Next: Phoebus Alarm Log panel William F Badgett Jr via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
