"# REM E-873 # # VERSION = 1 # TYPE = 1 # SEPARATOR = 32 # DIM = 4 # S" + "AMPLE_TIME = 0.00050 # NDATA = 7616 # # NAME0 = Commanded Position of Ax" + "is AXIS:1 # NAME1 = Actual Position of Axis AXIS:1 # NAME2 = Motor Curr" + "ent AXIS:1 # NAME3 = Signal Status Register of Axis AXIS:1 # # END_HEA" + "DER -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -" + "0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000" + "001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0." + "000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.00000" + "1 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0." + "0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36" + "877 -0.000001 0.000000 -0.0015 36877 -0.000001 0" # REM E-873 # # VERSION = 1 # TYPE = 1 # SEPARATOR = 32 # DIM = 4 # SAMPLE_TIME = 0.00050 # NDATA = 7616 # # NAME0 = Commanded Position of Axis AXIS:1 # NAME1 = Actual Position of Axis AXIS:1 # NAME2 = Motor Current AXIS:1 # NAME3 = Signal Status Register of Axis AXIS:1 # # END_HEADER -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0. -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000004 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000004 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000004 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 5 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.77 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 368770015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000004 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001-0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.00000115 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 3680-0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0-0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.00000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.00.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000004 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.0000 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.00000001 - 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.00005 36877 -0.00.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.0001-0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.0000 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.0000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 0 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.003 -0.0015 36877 -.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 367 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 0002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000005 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.00115 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000003 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000003 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 3012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000003 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000002 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000002 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 -0.000001 -0.0012 36877 -0.000001 -0.000001 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 0.000000 -0.0015 36877 -0.000001 -0.0000
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
