1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: EPICS, PostgreSQL, Archive Engine: doubts about how to use them
From: Oscar Ibañez via Tech-talk <[email protected]>
Date: Thu, 12 Jan 2023 09:02:58 +0100
I am trying to set up a PostgreSQL RDMS to work together with EPICS to save some PV values. However, I am having doubts about how to do it, since the process is not clear to me.
First of all, I installed EPICS and I downloaded Phoebus. Both are running with no problem. In addition, I installed PostgreSQL. It seems to work fine. Then, I tried to learn how to connect EPICS and PostgreSQL, and I ended up reading Phoebus documentation about the RDB Archive Engine, and that was the point when I did no understand what I was doing.
https://control-system-studio.readthedocs.io/en/latest/services/archive-engine/doc/index.html
The document says that I need to download the archive engine from:
https://controlssoftware.sns.ornl.gov/css_phoebus
But I can't find any archive engine in that place.
In addition, I am confused about the rol of Phoebus in this problem. Why do I need to set up any preference in the Phoebus configuration to use the Archive Engine? Phoebus is just a software to create and to display graphical screen to monitor/check the control system. If I run the Archive Engine, that software will save PV values in the PostgreSQL tables that I want. So, I don't understand the relationship between Phoebus and the Archive Engine, since the documentation is in the CSS web.
Any help would be useful.
Regards.
Óscar
RE: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Abdalla Ahmad via Tech-talk
Prev: Re: areaDetector/ADPilatus Mark Rivers via Tech-talk
Next: RE: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: [External] Kniel Power Supply Leblanc, Gregory via Tech-talk
