1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: only use PVAccess
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Daykin, Evan" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Jan 2023 15:33:28 -0600
Hi Evan,
I haven't tested this recently, but you should be able to copy the base.dbd file from your Base/dbd directory into the source directory where you build that IOC binary and remove the inclusion of the rsrv.dbd file from the end of that copy. The base.dbd file only needs to be copied into the source directory, don't add it to the Makefile at all. Then rebuild the IOC (make sure you do either a 'make rebuild' or 'make clean; make') and the CA server should have been excluded from the resulting binary.
- Andrew
On 1/18/23 2:45 PM, Daykin, Evan via Tech-talk wrote:
I just had someone ask me if I could disable channel access on one of our test IOCs, so they could make sure that their application correctly processes PVAccess data. For now, we decided on blocking CA traffic on the client end. Is there a way to completely disable CA from being built into an IOC?
-Evan
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: [email protected]
cid:image002.jpg@01D07041.57B6D750
Complexity comes for free, Simplicity you have to work for.
Re: only use PVAccess Andrew Johnson via Tech-talk
only use PVAccess Daykin, Evan via Tech-talk
Prev: only use PVAccess Daykin, Evan via Tech-talk
Next: Re: only use PVAccess Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
