1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: [External] Re: Keysight 34980A SCPI StreamDevice
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Jan 2023 19:04:37 +0000
Andrew,
Thanks, coupled with some advice from Peter, that seems to have done the trick.  AI is indeed a more appropriate record type.
     Greg
Sent: Tuesday, January 24, 2023 1:18 PM
To: Leblanc, Gregory <[email protected]>; [email protected]
Subject: [External] Re: Keysight 34980A SCPI StreamDevice
Use caution with links and attachments.
Hi Greg,
I'm not a StreamDevice expert at all, but it seems to me that your design is expecting the number 9.9e37 to fit into a longin record's VAL field. In EPICS the word "long" was set in the days when an int was only 16 bits wide, so a DBF_LONG is only an epicsInt32 with a maximum value of 2,147,483,648 ~ 2.15e9.
Changing the record into an ai should fix that.
- Andrew
On 1/24/23 11:59 AM, Leblanc, Gregory via Tech-talk wrote:
Hi again,
Still trying to run down some more details about talking to these lovely Keysight boxes via EPICS.  I've got the stock SCPI stuff working, so next I wanted to read some resistance values.  I added this to my protocol file:
getResistance {
    out "measure:resistance? \$1,\$2,\$3";
    in "%E";
And added this to my .db file:
record(longin, "$(P)$(R)GetIG")
    field(DESC, "Get Alphatross Ion Gauge Value")
    field(DTYP, "stream")
    field(INP,  "@devswag6.proto getResistance(10,0.1,(@5012)) $(PORT) $(A)")
After starting the ioc, I can do ' dbtr swag6testGetIG`, which sends the correct string, and gets a reply from the mainframe.  What I'm stuck on is handing the reply.  The box replies with:
 +9.90000000E+37\n
But the way I have things configured I get:
2023/01/24 12:49:07.000698 LAN0 swag6testGetIG: Format "%E" has data type double which is not supported by "swag6testGetIG".
It seems like that should work, based on: https://paulscherrerinstitute.github.io/StreamDevice/formats.html
I don't know if I managed to compile StreamDevice with some missing library, or if I've done something else wrong along the way.
Thanks for any pointers,
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
Complexity comes for free, Simplicity you have to work for.
Keysight 34980A SCPI StreamDevice Leblanc, Gregory via Tech-talk
Re: Keysight 34980A SCPI StreamDevice Andrew Johnson via Tech-talk
Prev: Re: Keysight 34980A SCPI StreamDevice Andrew Johnson via Tech-talk
Next: RE: abdf1 driver that logs with logMsg? - I know this is a real long shot Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: RE: [External] Re: Keysight 34980A SCPI StreamDevice Leblanc, Gregory via Tech-talk
