1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: abdf1 driver that logs with logMsg? - I know this is a real long shot
From: Maren Purves via Tech-talk <[email protected]>
Date: Wed, 25 Jan 2023 15:18:40 -1000
I'll have to look into that now that our computer system is functional again (never worked with procServ).
A console switch is similar to a terminal server, but with buffers for each port.
Thanks Mark,
Maren
On Tue, Jan 24, 2023 at 10:36 AM Mark Rivers <[email protected]> wrote:
Ø  (I assume that works the same way for console switches?)
What is a console switch?  It should work because there is only a single connection to the device, and that is from procServ.  Users connect to procServ which allows multiple users to share a single connection.  Everyone sees what everyone else is typing and receiving.
Ø  Our telescope operators open a telnet session to each of the iocs at the start of the night in case they need to reboot one. Does the one prevent the other?
I don’t use telnet to the IOCs, so I am not sure.  But if you use procServ they will be able to reboot using that and so may not need a telnet connection to the IOC at all.
Sent: Saturday, January 21, 2023 5:28 PM
Cc: [email protected]
Thank you Mark,
yes, I do have the source code, but those print statements are in state notation code rather than in the driver. I can try replacing the printf in there.
I did not know that there is a way around only one person being able to access a terminal server (I assume that works the same way for console switches?) at a time.
Thanks, will have to look into details later (it's not the only problem we're having at the moment),
Maren
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory / JCMT
On Sat, Jan 21, 2023 at 5:47 AM Mark Rivers <[email protected]> wrote:
Hi Maren,
I assume you don't have access to the source code for the abdf1 driver, so you can't change the printf() to logMsg()?
We log the console output on all of our vxWorks systems as follows:
  • Connect the console serial port to an Ethernet terminal server.
  • Run the procServ program on a Linux machine.  Here is an example of the command used to start one of them:
/usr/local/bin/procServ --logstamp -n "13IDA_IOC" -L /home/epics/logs/13IDA.log 20024 /usr/bin/telnet gsets2.cars.aps.anl.gov 4004
That does the following:
  • Connects to the terminal server gsets2 via telnet on port 4004
  • Logs all of the console output to the file /home/epics/logs/13IDA.log
  • Allows multiple users on the Linux system to connect to the console port at the same time using the command:
telnet localhost 20024
The log file has a timestamp on every line, so you can see when error messages were generated.  Here is an example:
[Fri Jan 20 09:17:14 2023] sevr=minor Motor motion timeout ERROR on card: 2, signal: 0
This solution won't put the log output in the same place that logMsg would, but at least it will be on your Linux server where you can search it.
From: Tech-talk <[email protected]> on behalf of Maren Purves via Tech-talk <[email protected]>
Sent: Saturday, January 21, 2023 2:59 AM
To: EPICS tech-talk <[email protected]>
Subject: abdf1 driver that logs with logMsg? - I know this is a real long shot
Hi all,
we have an EPICS ioc (ppc604, mvme5100 to be exact) that connects to an Alle Bradley PLC using the abdf1 driver. We have some errors recorded from state notation language but that only goes into the buffer of the console switch. We use logMsg (not sure exactly where that comes from) to write to a nightly EPICS.log which is much easier to access than the console switch that only allows one connection at a time.
The abdf1 version used dates back to 2011, and we're still running EPICS 3.13.8 on VxWorks 5.5. While I'd like to upgrade to EPICS 7 and for many (at least the monitoring) things softIocs we don't have the effort to do that in a more than very piecemeal way, if at all.
TIA,
Maren Purves
Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Ralph Lange via Tech-talk
abdf1 driver that logs with logMsg? - I know this is a real long shot Maren Purves via Tech-talk
Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Mark Rivers via Tech-talk
Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Maren Purves via Tech-talk
RE: abdf1 driver that logs with logMsg? - I know this is a real long shot Mark Rivers via Tech-talk
Prev: Re: Trusted-CI Webinar on EPICS/RTEMS Cybersecurity Gedare Bloom via Tech-talk
Next: RE: EPICS deb/rpm packaging Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: abdf1 driver that logs with logMsg? - I know this is a real long shot Mark Rivers via Tech-talk
Next: Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Ralph Lange via Tech-talk
