Hi Mark,
Thanks for the explanation.
Best Regards
Abdalla.
Sent: Thursday, January 26, 2023 4:42:36 PM To: Abdalla Ahmad <[email protected]>; Mark Rivers <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: Strange memory leak with ADAravis
Hi Abdalla,
I just looked at ADGenICam.cpp and ADAravis.cpp. I think I see the problem. Neither of those checks to see if the camera is already acquiring when ADAcquire is set to 1. ADAravis always allocates a new NDArray when Acquire is set to 1. I think that will
cause the memory growth you are seeing. It needs to be fixed, but for now you just need to make sure that the camera is done before setting Acquire=1.
This should not be a problem for a step-scan, because at each point in the scan the script should wait for the acquisition to complete before starting the next one. That will happen automatically with the sscan record, for example, because it uses ca_put_callback
which waits for the camera to be done.
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Thursday, January 26, 2023 8:26 AM To: Abdalla Ahmad <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: Strange memory leak with ADAravis
Hi Abdalla,
When the Acquire command was sent was the camera already acquiring, or had it stopped? Can you send a screen shot of ADAravis so I can see how you had it configured when you were having the issue?
Sent: Thursday, January 26, 2023 1:07 AM To: Mark Rivers <[email protected]> Cc: [email protected] <[email protected]> Subject: RE: Strange memory leak with ADAravis Hello Mark
I revisited this issue recently and I noticed that the cause for increasing the allocated buffers is a python script running in a loop doing calculation on images received from the camera. After debugging I found that the script is doing “Acquire” inside the loop so every loop iteration the camera receives an Acquire command “CAM_PREFIX:Acquire”, I moved the command outside the loop and since yesterday, the IOC is working fine with very reasonable performance and resources. I would like to ask why the camera is allocating buffers every time an acquire command is received? Wouldn’t that cause an issue in a step-scan-based application?
Thanks in advance. Abdalla.
Hi Abdalla,
Ø Both the server and the CPU are using the same OS (CentOS 7.5) with the same base and support modules versions but the PC is an i7/8GB while the server is only 4 cores/4GB RAMs. Ø The server has another 15 IOCs running.
For the server, do you mean that each virtual machine has 4 cores/4GB. Does each IOC run in its own virtual machine? How many real cores and physical memory on the server?
I don’t think that running on a low-end virtual server should cause the memory usage of the IOC application to increase like you were seeing, but I don’t have any experience with virtual machines.
Hello Mark
I moved the IOC to my PC instead of running on a virtual server, I ran it for couple of times and the memory usage is good, right now it will be running for few days to see how much it will consume. Both the server and the CPU are using the same OS (CentOS 7.5) with the same base and support modules versions but the PC is an i7/8GB while the server is only 4 cores/4GB RAMs. The server has another 15 IOCs running. Could be the server is suffering somehow in the performance?
Best Regards, Abdalla.
> I noticed that PollUsedMem.SCAN was set to “1 second”, when it was set to 1 second the buffers used and allocated were increasing by around 10-20 frames/s, when I set it to I/O Intr the buffers counts were constant and memory usage was perfectly fine.
SCAN=I/O Intr does not work for PoolUsedMem.SCAN, you need to use a periodic scan rate like "1 second". If you use I/O Intr it is not getting the statistics, so it is just hiding the problem.
You said that when it was 1 second the buffers used and allocated were increasing by 10-20 frames/s. That does not make sense for the screen shot you sent, because the acquisition time was 10 seconds. Your commonPlugins.adl screen shows you only have 2 plugins loaded and active, NDPluginStdArrays and NDPluginStats. In the worst possible case under those conditions, if both plugins and the camera had a memory leak, the number of buffers used and allocated could only increase by 0.1 frames/s * 3 = 0.3 frames/s. Were you really using a 10 second acquire time when you had the problem?
Please change PoolUsedMem.SCAN to 1 second and report again how the buffers used and allocated are increasing under the exposure time conditions you use when you have seen the memory problem in the past.
> Please note that in this setup (while also failing before) I set QSIZE in the st.cmd to 3000 then 10000.
I am confused, your screen shot of commonPlugins.cmd shows that QSIZE was set to 100 (Free column), not 3000 or 10000. For these plugins there is no reason to set a QueueSize that large. Generally you only need a large queue size like that for the file saving plugins, where you want to buffer frames because the camera is collecting faster than the files can be saved to disk. Note that QueueSize is normally in autosave, so the value in use may not be the QSIZE you set in the file. You can change it in the main medm screen for that plugin.
Hello Mark
I mistakenly rebooted the IOC when huge buffers were allocated (+120K), so I attached an image of the working setup. I noticed that PollUsedMem.SCAN was set to “1 second”, when it was set to 1 second the buffers used and allocated were increasing by around 10-20 frames/s, when I set it to I/O Intr the buffers counts were constant and memory usage was perfectly fine. Please note that in this setup (while also failing before) I set QSIZE in the st.cmd to 3000 then 10000.
After this happens please send the screen shots for ADAravis and commonPlugins.
Sent from my iPhone
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
