1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Kernel showing segfaults in motorPoller.
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 26 Jan 2023 20:04:35 +0100
On Thu, 26 Jan 2023 at 19:02, Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov> wrote:
We are experimenting several segfaults with motor IOCs here. Behavior is unpredictable, but i suspect common cause.
Any tips on how to debug this?
Get core dumps.
Most probably it's enough to set the core file size before running your IOC:
$ ulimit -c unlimited
You can always check the current limit with 'ulimit -a'.
Then load the core file into gdb and have a look.
Cheers,
~Ralph
Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
Prev: Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Problems using Universal I/O Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Re: Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
ANJ, 27 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
