Subject: |
Minor Sequencer tests issue under EPICS 7.0.7 |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 27 Jan 2023 13:10:03 +0100 |
All,
When compiled against EPICS Base 7.0.7, the test suite of the Sequencer fails if you "make runtests" a second time without "make clean" in between. (The linker complains about an undefined reference to "main".) A simple fix restores the original behavior (patch attached and sent upstream).
This is entirely a problem of the unit tests, not of the sequencer itself. There is no reason to update your installation unless you're facing the issue.
Cheers, ~Ralph
seq-2.2.9-base707-fix.patch
Description: Binary data
Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Maren Purves via Tech-talk
REMINDER: EPICS Code-a-thon Collaboration Workshop - Book your space today Diamond Events via Tech-talk
<2023>
2025
2026
Re: Kernel showing segfaults in motorPoller. Ralph Lange via Tech-talk
EPICS collaboration meeting - save the date Pierrick M Hanlet via Tech-talk
<2023>
2025
2026
