1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: Allen-Bradley PLC question
To: Matt Rippa <[email protected]>, Maren Purves <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Wed, 1 Feb 2023 16:47:25 +0000
Hi Matt,
Thanks very much for sharing that.
Since my tech-talk post I found that there is a third-party module for the SLC500 series PLCs that implements Modbus TCP/IP Server, the Prosoft MVI46_MNET.
https://www.prosoft-technology.com/prosoft/download/695/6439/file/MVI46_MNET_Datasheet.pdf
https://www.prosoft-technology.com/content/download/898/7470/file/mvi46_mnet_user_manual.pdf
This should work with the EPICS Modbus module, which is a Modbus client.  It would require some minor changes to the ladder logic to put the data to/from EPICS in a different location.
The module is no longer manufactured but is available on the used market.
The User Manual says that a Windows configuration program is required to initially configure the module.  I have sent an inquiry to Prosoft asking if that program is still available, and what version of Windows is required.
Sent: Wednesday, February 1, 2023 10:07 AM
To: Maren Purves <[email protected]>
Cc: Mark Rivers <[email protected]>; Talk EPICS Tech <[email protected]>
Subject: Re: Allen-Bradley PLC question
Hi Mark and Maren,
We have the abdf1 driver which we converted to use OSI about 5 years ago. Jeff helped us at the time. It depends on drvserial, which was also converted.
You may also be able to supplement the PLC with an Ethernet module. I don't know if that's something that works for your exact model. I think we're using PLC5. With this setup we used a Linux compatible driver from ORNL. I believe it's the enetOrnlPLC5 driver. I'll find out and let you know. It's on one of our older build systems.
-Matt
On Tue, Jan 31, 2023, 9:01 AM Maren Purves via Tech-talk <[email protected]> wrote:
Hi Mark,
finding it listed with no contact at https://epics.anl.gov/modules/bus.php#RS%2d232%2dABDF1, I can produce a tarball if nobody else comes forward.
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory / JCMT
On Tue, Jan 31, 2023 at 8:46 AM Mark Rivers <[email protected]> wrote:
Hi Maren and all,
Is that abdf1 driver available for download anywhere?
It looks like one option is the ProSoft MVI46-MNET which is a module that plugs into the SLC chassis and provide a Modbus TCP/IP sever in the PLC.  That should directly work with EPICS, and require just a small change to my ladder logic.  The module is not made anymore, but there appear to be quite a few available on the used market.
Sent: Tuesday, January 31, 2023 12:34 PM
Cc: [email protected]
Hi Mark,
we're still using the abdf1 driver that originated from Jeff Hill in 1995 (says the code) and that I recently asked about. I know that the communication goes through the serial line (which in our case is connected to a console switch and Ethernet from thereon). I don't know anything about the PLC hardware (or internal software) off the top of my head.
Maren Purves
On Tue, Jan 31, 2023 at 7:30 AM Mark Rivers via Tech-talk <[email protected]> wrote:
Folks,
I have two old Allen-Bradley SLC 500 PLCs with the SLC 5/03 processors.  These are communicating with EPICS via the VME 6008-SV1 scanner card, which is connected to a 1747-DCM “Direct Communication Module” in the PLC.  These communicate via the Remote I/O (RIO) protocol.  We are planning to eliminate the VME crates on our beamline, but really hope to avoid spending the $50K or so that it would cost to replace the PLCs.
I am therefore looking for another way to communicate from EPICS to the PLCs. I am not aware of any device that replaces the VME 6008-SV1, for example a PCI-E card or an Ethernet adapter device.  Does anyone else know of one?
The SLC-5/03 has an RS-232 serial port 0 that normally uses the DF1 protocol.  It is how we program it from a PC, for example.  It also has an RS-485 port 1 that uses the DH-485 protocol.  It does not have an Ethernet connection.
The RS-232 port can be configured to use be a Modbus master.  Unfortunately it cannot be configured to be a Modbus slave, which would allow simple connection to EPICS via the Modbus module.  However, I could enhance the Modbus module to add support for acting as a Modbus slave, and the PLC could then connect to the EPICS IOC and send and receive data.
Does anyone know of another option, for example with the DH-485 port?
RE: Allen-Bradley PLC question Mark Rivers via Tech-talk
Re: Allen-Bradley PLC question Maren Purves via Tech-talk
Re: Allen-Bradley PLC question Matt Rippa via Tech-talk
Prev: Re: Allen-Bradley PLC question Matt Rippa via Tech-talk
Next: Re: Quickstart Error trying P4P Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: RE: Allen-Bradley PLC question Mark Rivers via Tech-talk
