1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Periodic SCAN issue in EPICS Archiver Appliance
From: "Shankar, Murali via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 16 Feb 2023 15:22:02 +0000
>> basic handling of sample modes in the archiver appliance is basically the same as with the older channel archiver.
This is correct.
There is also question 4 in the FAQ that has some more details - https://slacmshankar.github.io/epicsarchiver_docs/faq.html
You can also look at "camonitor -m al X2:IOC:-FM1_INMON" and see which samples make it into the archiver. This can sometimes help you figure out where the issue is.
Murali
Prev: Re: Periodic SCAN issue in EPICS Archiver Appliance Kasemir, Kay via Tech-talk
Next: Moxa terminal server question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Periodic SCAN issue in EPICS Archiver Appliance Vishnu Patel via Tech-talk
Next: Re: Periodic SCAN issue in EPICS Archiver Appliance Shankar, Murali via Tech-talk
ANJ, 10 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
