1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Archiver appliance recover removed signals.
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Wed, 1 Mar 2023 19:23:57 +0000
Re: Can we recover access to this data that is still on disk?
Yes; one option is to use the retiredPVTemplate; there's some documentation in the user guide. Also, I think, Rebecca Williams (thanks!) recently added support for "retrieval for retired PV without template"; this is in the main branch but has not been released yet. If you want, you can try that out as it's quite convenient.
Re: If we delete this data (which has been backed up in our backup system) is it possible to restore it if someone wants to access it later?
Yes; pretty much the same answer as above. Restore it into its original location and then use the retiredPVTemplate options.
Murali
Prev: Control System Engineer position at ALS in LBNL Miroslaw Dach via Tech-talk
Next: EPICS Collaboration meeting - registration is now open Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Archiver appliance recover removed signals. Phillip A. Sorensen via Tech-talk
Next: Control System Engineer position at ALS in LBNL Miroslaw Dach via Tech-talk
