1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: [EXTERNAL] Can not open more than one Phoebus instance at the same time
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "javicruz at ugr.es" <javicruz at ugr.es>
Date: Thu, 9 Mar 2023 18:03:53 +0000
Check if your launcher script includes the '-server {port}' option and if so, remove it.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of javicruz--- via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, March 9, 2023 12:40 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Can not open more than one Phoebus instance at the same time
Hi:
We are not able to open more than one Phoebus instance at once (in the same server).
Once we have launched the first instance, if we try to launch another one , the second window -with the new Phoebus instance- doesn't appear. (if we close the 1st instance, then yes we can open it again).
That happens in the same user console or with different users in the same server. We have also tried it in a Centos7 installation and in Windows Server 2019.
Following the documentation in https://control-system-studio.readthedocs.io/en/latest/running.html# , apparently this shoud be possible by default.
We normally use the " phoebus.sh " command but we have tried to add the " -app " parameter with different names too, and we get the same behaviour.
Are we missing something in the Phoebus or in the Java configuration?
We'll appreciate a lot any kind of help.
Best regards,
   Javi.
Re: [EXTERNAL] Can not open more than one Phoebus instance at the same time javicruz--- via Tech-talk
Prev: Can not open more than one Phoebus instance at the same time javicruz--- via Tech-talk
Next: NDPluginXIP to compile the RIXSCam detector Nicolas Guilhermo Silva Moliterno via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: [EXTERNAL] Can not open more than one Phoebus instance at the same time javicruz--- via Tech-talk
ANJ, 10 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
