1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: [EXTERNAL] DeferredMoves without setting moving flag
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: "Pearson, Matthew" <pearsonmr at ornl.gov>, Laurenz Rettig <rettig at fhi-berlin.mpg.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 10 Mar 2023 17:04:14 +0000
Oh, I was to fast with my first response.
The line you wrote, Matt, could go into the generic code, right ?
/Torsten
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Pearson, Matthew via Tech-talk" <tech-talk at aps.anl.gov>
Reply-To: "Pearson, Matthew" <pearsonmr at ornl.gov>
Date: Friday, 10 March 2023 at 17:50
To: Laurenz Rettig <rettig at fhi-berlin.mpg.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: RE: [EXTERNAL] DeferredMoves without setting moving flag
Certainly that behavior can be confusing. We enable deferred moves, set the position, and a motor appears to be moving before we say ‘Go’. However, I think it is necessary so that the motor record doesn’t think the move is completed before we have started moving. If you are relying on a callback or forward links or looking for a DMOV 0->1 transition, you’ll be depending on this behavior.
Also that line in asynMotorController.cpp applies to all kinds of moves and not just deferred moves. This is necessary for the same reasons, to prevent the motor record thinking that the move is complete before it’s even started and the polling function has chance to return the correct moving status. It’s likely almost every Asyn motor driver depends on that line in the base class writeFloat64 function.
In the poll() function in your derived class, it’s usually handled by looking at the deferred move flag for an axis. If deferred moves is enabled, then the poller reports motorStatusDone=0, something like:
if (deferred_move) {
  moving = true;
} else {
  //calculate moving flag as normal
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Laurenz Rettig via Tech-talk
Sent: Friday, March 10, 2023 11:17 AM
To: tech-talk at aps.anl.gov
Subject: [EXTERNAL] DeferredMoves without setting moving flag
I've been working on an asyn motor controller with DeferredMoves. This in principle works, however I noticed that when DeferedMoves is enabled, and I change the setpoint of an axis, the moving flag is raised for a short time (i.e. DMOV=0), even though the axis is not moving yet. I would like to get rid of this behavior.
As far as I understand it, this is probably induced by the calls to "pAxis->setIntegerParam(motorStatusDone_, 0);" here:
https://github.com/epics-modules/motor/blob/34474ed958838ea5083f598fa4bd9f1ca7e1821c/motorApp/MotorSrc/asynMotorController.cpp#L317
and the flag is reset by the next call of the axis poll() function.
Is there a simple way to avoid this, or do I have to rewrite the whole writeFloat64 function in my controller driver, and remove these lines?
Laurenz
Dr. Laurenz Rettig                  rettig at fhi-berlin.mpg.de
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6                         Tel: +49 30 8413 5225
14195 Berlin, Germany                  Fax: +49 30 8413-5387
RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
DeferredMoves without setting moving flag Laurenz Rettig via Tech-talk
Prev: Re: DeferredMoves without setting moving flag Torsten Bögershausen via Tech-talk
Next: RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
ANJ, 10 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
