1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: NDPluginXIP to compile the RIXSCam detector
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Nicolas Guilhermo Silva Moliterno <nicolas.moliterno at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: SWC <swc at lnls.br>
Date: Fri, 10 Mar 2023 21:07:10 +0000
Hi Nicolas,
Ø  From what I understand, RIXSCam needs NDPluginXIP ? Because I understand this plugin is specific for this detector.
Ø  However, I couldn't find it anywhere if you can send it to me to compile.
I don’t know what NDPluginXIP is.  I don’t have the code, and I can’t find it on the Web.
The IOC should start fine if you comment out these lines:
NDPluginXIPConfigure("XIP1", $(QSIZE), 1, "$(PORT)", 0, -1, -1)
dbLoadRecords("$(ADRIXSCAM_PLUGIN)/db/NDPluginXIP.template", "P=$(PREFIX),R=XIP1:,  PORT=XIP1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
set_requestfile_path("$(ADRIXSCAM_PLUGIN)", "Db")
Ø  And after the compilation, the correct thing would be to have the envPaths at the end of the compilation,
but this file was not created, so it is not possible to run the IOC, the st.cmd does not work.
That is because you are building for the windows-x64 architecture, but /iocs/rixscamIOC/iocBoot/iocRixsCam/Makefile is using ARCH=windows-x64-static.  You need to change that line to ARCH=windows-x64.  Then it will build the envPaths and dllPath.bat for you when you do “make clean”, “make”.
The error message you showed was that Windows could not find the file “NDPlugin.dll”.  That is because you need to set your PATH so Windows can find that file.  Once you run “make” in the iocRicsCam directory it will create the file dllPath.bat.  Execute that batch file before running the IOC.
From: Nicolas Guilhermo Silva Moliterno <nicolas.moliterno at lnls.br>
Sent: Friday, March 10, 2023 12:53 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
Hi Mark, thanks for the help.
Adding the line as you said to MakeFile, the compilation worked :). But other doubts occurred to me.
- I am sending the complete output of make.
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam>make
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./configure install
make[1]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/configure'
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/configure/O.windows-x64'
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/configure/O.windows-x64'
make[1]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/configure'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./rixscamSupport install
make[1]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamSupport'
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[2]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamSupport/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamSupport/O.windows-x64'
make[1]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamSupport'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./rixscamApp install
make[1]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src install
make[2]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/src'
make[3]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/src/O.windows-x64'
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m rixscam.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        rixscam.obj ../rixscam.cpp
"Installing dbd file ../../../dbd/rixscamSupport.dbd"
mkdir ../../../dbd
"Installing generic include file ../../../include/rixscam.h"
mkdir ../../../include
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251    -DH5_BUILT_AS_DYNAMIC_LIB    -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        -c ../rixscam.cpp
rixscam.cpp
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\rixscamApp\src\rixscam.cpp(303) : Note >>>> Logging turned on!
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\rixscamApp\src\rixscam.cpp(528) : Note >>>> It may be beneficial to constrain sizeX/Y to be a multiple of binX/Y
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\rixscamApp\src\rixscam.cpp(718) : Note >>>> Force grab_setup, even when ROI unchanged (bug in xcmclm?)
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\rixscamApp\src\rixscam.cpp(1163): warning C4101: 'node': unreferenced local variable
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\rixscamApp\src\rixscam.cpp(1422) : Note >>>> This might not be thread-safe
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64      -out:rixscam.dll -implib:rixscam.lib         rixscam.obj      C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/lib/windows-x64/xcmclm_x64.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/lib/windows-x64/ADBase.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/lib/windows-x64/asyn.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/netCDF.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick++.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/coders.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jbig.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jp2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/bzlib.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/png.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/webp.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/lcms.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/ttf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/wmf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/filters.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/tiff.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jpeg.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/xml2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/NeXus.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/hdf5.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/blosc.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/szip.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/zlib.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbRecStd.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbCore.lib  C:\EPICS\base-3.15.9/lib/windows-x64/ca.lib  C:\EPICS\base-3.15.9/lib/windows-x64/Com.lib gdi32.lib oleaut32.lib
   Creating library rixscam.lib and object rixscam.exp
Generating code
Finished generating code
"Installing shared library ../../../bin/windows-x64/rixscam.dll"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing library ../../../lib/windows-x64/rixscam.lib"
mkdir ../../../lib
mkdir ../../../lib/windows-x64
make[3]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/src/O.windows-x64'
make[2]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/src'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./Db install
make[2]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/Db'
make[3]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/Db/O.windows-x64'
"Installing template file ../../../db/RIXSCam.template"
mkdir ../../../db
make[3]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/Db/O.windows-x64'
make[2]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp/Db'
make[1]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/rixscamApp'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./iocs install
make[1]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./rixscamIOC install
make[2]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC'
make[3]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/configure'
make[4]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/configure/O.windows-x64'
make[4]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/configure/O.windows-x64'
make[3]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/configure'
make[3]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp'
make[4]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/Db'
make[5]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/Db/O.windows-x64'
make[5]: Nothing to be done for 'install'.
make[5]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/Db/O.windows-x64'
make[4]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/Db'
make[4]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/src'
make[5]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/src/O.windows-x64'
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m rixscamAppMain.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include         -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        rixscamAppMain.obj ../rixscamAppMain.cpp
"Creating dbd file rixscamApp.dbd"
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/dbd -IC:\EPICS\base-3.15.9/dbd -o rixscamApp.dbd rixscamSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd aliveSupport.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/dbd -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/dbd -IC:\EPICS\base-3.15.9/dbd    -o rixscamApp_registerRecordDeviceDriver.cpp ../O.Common/rixscamApp.dbd rixscamApp_registerRecordDeviceDriver C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC
perl -CSD C:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m rixscamApp_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include         -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        rixscamApp_registerRecordDeviceDriver.obj rixscamApp_registerRecordDeviceDriver.cpp
"Installing created dbd file ../../../dbd/rixscamApp.dbd"
mkdir ../../../dbd
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251    -DH5_BUILT_AS_DYNAMIC_LIB    -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include         -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        -c rixscamApp_registerRecordDeviceDriver.cpp
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251    -DH5_BUILT_AS_DYNAMIC_LIB    -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include         -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/include  -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include/os/WIN32 -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/include   -IC:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/include -IC:\EPICS\base-3.15.9/include/compiler/msvc -IC:\EPICS\base-3.15.9/include/os/WIN32 -IC:\EPICS\base-3.15.9/include        -c ../rixscamAppMain.cpp
rixscamAppMain.cpp
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64             -out:rixscamApp.exe        rixscamApp_registerRecordDeviceDriver.obj rixscamAppMain.obj     ../../../../../lib/windows-x64/rixscam.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/lib/windows-x64/xcmclm_x64.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/lib/windows-x64/NDPlugin.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/lib/windows-x64/ADBase.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/netCDF.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick++.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/coders.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jbig.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jp2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/bzlib.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/png.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/webp.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/lcms.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/ttf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/wmf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/filters.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/tiff.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jpeg.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/xml2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/NeXus.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/hdf5.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/blosc.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/szip.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/zlib.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/lib/windows-x64/asyn.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/alive-R1-1-0/lib/windows-x64/alive.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/autosave-R5-9/lib/windows-x64/autosave.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/busy-R1-7/lib/windows-x64/busy.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/calc-R3-7-1/lib/windows-x64/calc.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/iocStats-3-1-15/lib/windows-x64/devIocStats.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/sscan-R2-11-1/lib/windows-x64/sscan.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/lib/windows-x64/seq.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/seq-2-2-5/lib/windows-x64/pv.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbRecStd.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbCore.lib  C:\EPICS\base-3.15.9/lib/windows-x64/ca.lib  C:\EPICS\base-3.15.9/lib/windows-x64/Com.lib gdi32.lib oleaut32.lib psapi.lib
Generating code
"Installing created executable ../../../bin/windows-x64/rixscamApp.exe"
mkdir ../../../bin
make[5]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/src/O.windows-x64'
make[4]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp/src'
make[3]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/rixscamApp'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./iocBoot install
make[3]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/iocBoot'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./iocRixsCam install
make[4]: Entering directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/iocBoot/iocRixsCam'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/iocBoot/iocRixsCam'
make[3]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC/iocBoot'
make[2]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs/rixscamIOC'
make[1]: Leaving directory 'C:/Users/nicolas.moliterno/Downloads/synApps_6_0/my_synApps/support/areaDetector-R3-3-1/ADRIXSCam/iocs'
- Output of command dir lib\windows-x64
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam>dir lib\windows-x64
 Volume in drive C has no label.
 Volume Serial Number is 1A34-D5A4
 Directory of C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam\lib\windows-x64
03/10/2023  12:52 PM    <DIR>          .
03/10/2023  12:52 PM    <DIR>          ..
03/10/2023  12:52 PM            10,436 rixscam.lib
               1 File(s)         10,436 bytes
               2 Dir(s)   8,132,100,096 bytes free
- Errors that show when I try to run st.cmd (screenshot)
Thx (:
Grupo SWC-Software de Controle / Control Software Group
Laboratório Nacional de Luz Síncrotron - LNLS Centro Nacional de Pesquisa em Energia e Materiais - CNPEM
De: Mark Rivers <rivers at cars.uchicago.edu>
Enviado: quinta-feira, 9 de março de 2023 17:45
Para: Nicolas Guilhermo Silva Moliterno <nicolas.moliterno at lnls.br>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Assunto: RE: NDPluginXIP to compile the RIXSCam detector
Hi Nicolas,
I believe I understand the problem.  I don’t think the problem is related to NDPluginXIPApp, the problem is in building the rixscam library itself.
This is the link command that is failing. I have added line terminators to make it easier to read, and omitted some of the libraries for clarity:
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_load_seq
The problem is that it is not linking with the vendor file xcmclm_x64.lib which is provided here https://github.com/areaDetector/ADRIXSCam/blob/master/rixscamSupport/os/windows-x86-static/xcmclm_x64.lib
That appears to me to be an error in the Makefile.  I think you should add the line below at line 19 in the Makefile https://github.com/areaDetector/ADRIXSCam/blob/9d313b7131375bc7945123a30674a7520b66a148/rixscamApp/src/Makefile#L19
LIB_LIBS += xcmclm_x64
Let me know if that fixes the problem.  If not, send the complete output of make, and the output of this command run at the top-level of ADRIXSCam
dir lib\windows-x84
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Nicolas Guilhermo Silva Moliterno via Tech-talk
Sent: Thursday, March 9, 2023 12:12 PM
To: tech-talk at aps.anl.gov
Subject: NDPluginXIP to compile the RIXSCam detector
Hi everyone, I'm compiling a RIXSCam detector.
I have compiled EPICS BASE = 3.15.9
SYNAPPS = 6.0 with AreaDetector -> ADCore, ADSupport.
I found myself stuck with the following compilation errors that I believe are related to Plugin = NDPluginXIPApp,
but I couldn't find it anywhere to compile it, if anyone can help me.
Thanks.
C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support\areaDetector-R3-3-1\ADRIXSCam>"C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Auxiliary\Build\vcvarsall.bat" amd64
** Visual Studio 2019 Developer Command Prompt v16.11.24
** Copyright (c) 2021 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
mkdir ../../../dbd
rixscam.cpp
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64      -out:rixscam.dll -implib:rixscam.lib         rixscam.obj      C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADCore/lib/windows-x64/ADBase.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/asyn-R4-33/lib/windows-x64/asyn.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/netCDF.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick++.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/coders.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/Magick.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jbig.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jp2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/bzlib.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/png.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/webp.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/lcms.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/ttf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/wmf.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/filters.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/tiff.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/jpeg.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/xml2.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/NeXus.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/hdf5.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/blosc.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/szip.lib  C:\Users\nicolas.moliterno\Downloads\synApps_6_0\my_synApps\support/areaDetector-R3-3-1/ADSupport/lib/windows-x64/zlib.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbRecStd.lib  C:\EPICS\base-3.15.9/lib/windows-x64/dbCore.lib  C:\EPICS\base-3.15.9/lib/windows-x64/ca.lib  C:\EPICS\base-3.15.9/lib/windows-x64/Com.lib gdi32.lib oleaut32.lib
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_cancel_grab
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_set_target_temperature
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_get_cam_serial_number
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_cds_gain
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_grab
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_set_param
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_dll_version
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_ccd_power
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_grab_setup_1node
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_logging
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_discover
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_set_voltage
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_init
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_temp_cntrl_select_IO
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_cds_offset
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_set_timeout
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_send_temp_cntrl_command
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_terminate
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_initialise_spi
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_pulse
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_ifsver
rixscam.obj : error LNK2001: unresolved external symbol __imp_xcm_clm_fpgaver
rixscam.dll : fatal error LNK1120: 23 unresolved externals
make[3]: *** [C:\EPICS\base-3.15.9/configure/RULES_BUILD:292: rixscam.dll] Error 1120
make[2]: *** [C:\EPICS\base-3.15.9/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: *** [C:\EPICS\base-3.15.9/configure/RULES_DIRS:85: src.install] Error 2
make: *** [C:\EPICS\base-3.15.9/configure/RULES_DIRS:85: rixscamApp.install] Error 2
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
NDPluginXIP to compile the RIXSCam detector Nicolas Guilhermo Silva Moliterno via Tech-talk
RE: NDPluginXIP to compile the RIXSCam detector Mark Rivers via Tech-talk
RE: NDPluginXIP to compile the RIXSCam detector Nicolas Guilhermo Silva Moliterno via Tech-talk
Prev: Re: [EXTERNAL] DeferredMoves without setting moving flag Laurenz Rettig via Tech-talk
Next: RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: RE: NDPluginXIP to compile the RIXSCam detector Nicolas Guilhermo Silva Moliterno via Tech-talk
Next: Appending to existing records Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
ANJ, 10 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
