1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: asyn R4-44-1 available
Date: Wed, 15 Mar 2023 19:28:43 +0000
Folks,
Thanks to Jueri Tagger from BNL for finding a bug in the support for waveform output records and aao records in asyn R4-44.
asyn R4-44-1 is now available. This is from the release notes:
- devEpics
  - Fix problem with waveform out and aao records due to missing initialization of a private member variable in devAsynXXXArray.cpp.
- testErrorsApp
  - Add code to test the asynXXXArray->write() functions.
Home: https://github.com/epics-modules/asyn
Documentation: https://epics-modules.github.io/asyn
Release notes: : https://github.com/epics-modules/asyn/blob/master/RELEASE.md
asyn R4-44 available Mark Rivers via Tech-talk
Prev: AW: How is EPICS used at your facility? Loeher, Bastian Dr. via Tech-talk
Next: Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: asyn R4-44 available Mark Rivers via Tech-talk
Next: pv/ntndarray.h not found in areaDetector compilation Marco A. Barra Montevechi Filho via Tech-talk
