1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: About MAXv controller PV recognize problem
To: "[email protected]" <[email protected]>, whitetiger1123 <[email protected]>
Date: Fri, 17 Mar 2023 12:49:26 +0000
Hi Holyeong,
> If it is assumed that the software or the jumper setting of the MAXv contoller is correct, is it okay to judge that the MAXv controller can’t communication VME Bus?
I don't think that is a good assumption, I think it is much more likely that the jumpers are in the wrong position or that you have your startup commands incorrect than that you have a hardware problem.
I helped you with this identical problem in November 2022, showing you which jumpers to set.  You reported that when you followed my directions it worked fine.  This is the follow-up tech-talk message I posted which contains our offline e-mail thread.
From: Tech-talk <[email protected]> on behalf of whitetiger1123 via Tech-talk <[email protected]>
Sent: Thursday, March 16, 2023 7:40 PM
To: [email protected] <[email protected]>
Subject: About MAXv controller PV recognize problem
Before I ask a question, I would like to thank the epics tech talk for helping me. I’m a beginner in epics and RTOS, but I was able to come to this step with a lot of help. Really appreciate it.
I try to boot MVME6100 with epics st.cmd, MAXv controller. But it shows me a error like this :
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m2 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m3 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m4 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m5 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m6 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m7 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m8 motor_init_record_com(): card does not exist!
But “dbl”, this command shows me a pv list
-> dbl
oms:m1
oms:m2
oms:m3
oms:m4
oms:m5
oms:m6
oms:m7
oms:m8
value = 0 = 0x0
I can see EPICS IOC booting well, but MAXv card does not recognize PVs.
Before sending the MAXv controller repair, I would like to ask for your opinion as an expert.
Thank you and Best Regards,
Holyeong Baeg.
About MAXv controller PV recognize problem whitetiger1123 via Tech-talk
Prev: Re: The help command for VxWorks shell Di Wang via Tech-talk
Next: Re: Problem with PVA group def using .json file Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: About MAXv controller PV recognize problem whitetiger1123 via Tech-talk
Next: The help command for VxWorks shell Di Wang via Tech-talk
