1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Doubts about libpcre in compilation
From: NICOLE Remi via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Mar 2023 08:13:41 +0000
As I understand it, the PCRE library is used if your protocol file uses
regular expression for parsing input:
    getRegexTitle {
        out "REGEX_TITLE";
        in "%.1/<title>(.*)<\/title>/"
So, if your protocol files don't use this feature, you should be fine.
This is documented here:
https://github.com/paulscherrerinstitute/StreamDevice/blob/e6b2944c/streamApp/regexp.README
- https://paulscherrerinstitute.github.io/StreamDevice/setup.html
Cheers
Rémi NICOLE <[email protected]>
CEA/DRF/IRFU/DIS/LDISC
On Wed, 2023-03-22 at 22:12 +0000, Marco A. Barra Montevechi Filho via
Tech-talk wrote:
> Hello all, i have an areaDetector IOC which im cross-compiling for
> aarch64. The ioc also uses streamDevice 2.8.22 and is being compiled
> in an ubuntu 16.04 container.
> I have another ubuntu 16.04 old container in which i compiled it in
> the past, but he configuration of the container is kinda messy and im
> improving things.
> I remember i did something ugly in the old container and it has lpcre
> somewhere, but i couldnt find it, although i can recompile the ioc in
> it. I also couldnt solve the compilation issue in the new container
> withapt install libpcre3 libpcre3-dev or anything similar.
> So in the new container i just found PROD_SYS_LIBS_DEFAULT += pcre in
> a makefile, commented it and it compiled nicely.
> I understand its a lib for regex in perl and streamDevice might use
> it but might already have it out-of-the-box.
> My question is: am i breaking my IOC in ways im going to regret? Or
> just getting rid of old dependencies that are not needed anymore?
> Thanks for any help,
> Marco
> Aviso Legal: Esta mensagem e seus anexos podem conter informações
> confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo
> e considere eventual consulta ao remetente antes de copiá-la,
> divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano,
> por favor avise o remetente e apague-a imediatamente.
> Disclaimer: This email and its attachments may contain confidential
> and/or privileged information. Observe its content carefully and
> consider possible querying to the sender before copying, disclosing
> or distributing it. If you have received this email by mistake,
> please notify the sender and delete it immediately.
Re: Doubts about libpcre in compilation Marco A. Barra Montevechi Filho via Tech-talk
Prev: 回覆: Value of Renishaw absolute encoder exceeds its maximum Chiang, Liang-Chih [江良志] via Tech-talk
Next: Job Opportunity BESSY II Smith, William via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Doubts about libpcre in compilation Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Doubts about libpcre in compilation Marco A. Barra Montevechi Filho via Tech-talk
