1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: GitHub's new rsa ssh host-key
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Andrew Johnson <anj at anl.gov>, EPICS Tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 24 Mar 2023 15:07:24 +0000
Hej Andrew and all,
I stumbled accross the same problem today.
Found that they have a couple of fingerprints,
remove the old ones from my .ssh/known_hosts file,
and pasted in the 3 ones mentioned here:
<https://docs.github.com/en/authentication/keeping-your-account-and-data-secure/githubs-ssh-key-fingerprints>
Why do you have 20 IP addresses ?
Shouldn't there simply be a hostname ?
BR
/Torsten
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
Reply-To: Andrew Johnson <anj at anl.gov>
Date: Friday, 24 March 2023 at 15:59
To: EPICS Tech-talk <tech-talk at aps.anl.gov>
Subject: GitHub's new rsa ssh host-key
GitHub users note:
https://github.blog/2023-03-23-we-updated-our-rsa-ssh-host-key/
I actually have their original host-key on about 20 other IP addresses as well, the blog post doesn't mention those..
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Prev: GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Next: Re: GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 24 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
