Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Tech-Talk
Mailman
Search
Core-talk
Mailman
Search
QTi-talk
Search
Hw-talk
Search
Bugs
Documents
Links
Licensing
Format page
for printing
Search Tech-talk
Index
Date
Thread
Subject
Re: e_flex.exe error_base7.0.7 in win64
From
Ralph Lange via Tech-talk <
tech-talk at aps.anl.gov
To
EPICS Tech Talk <
Date
Thu, 30 Mar 2023 14:07:50 +0200
That bug was related to specific versions of the MinGW-w64 compiler and was fixed by switching to a newer compiler version. Probably unrelated.
You're using MSVC, so this doesn't apply, anyway.
Have you set up the environment for the MSVC correctly?
Please check the how-to at
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows.html
. You need to run the MSVC-provided batch scripts to set up the environment before running make.
Cheers,
~Ralph
lynn via Tech-talk
Prev:
lynn via Tech-talk
Next:
Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record
Hu, Yong via Tech-talk
Index:
Prev:
lynn via Tech-talk
Next:
Re:Re: e_flex.exe error_base7.0.7 in win64
lynn via Tech-talk
Index:
ANJ
, 11 Apr 2023
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
