#define is allowed in the sequencer. Here is an example of a sequencer program that uses it:
Perhaps your problem is in this line:
assign test_array to {"{S}:r1", "{S}:r2", "{S}:r3"};
Where is the S macro defined?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Hyung Jin Kim via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, April 2, 2023 7:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: #define usage in Sequencer
Dear All,
I tried to set a size of array using predefined value in sequencer code as follows:
program sncTest
#define A_SIZE 3
double test_array[A_SIZE];
monitor test_array;
However, it gives an error when it is compiled. #define is not allowed in sequencer. An used sequencer version is 2-2-6.
../sncTest.stt:3: lexical error: invalid character
../sncTest.stt:3: syntax error near token ''
../sncTest.stt:3: parser giving up
- #define usage in Sequencer Hyung Jin Kim via Tech-talk
Re: #define usage in Sequencer Mark Rivers via Tech-talk
<2023>
<2023>
ANJ, 02 Apr 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
