1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: areadetector on windows, xml2 done, now Lightfield
From: William Kirstaedter via Tech-talk <tech-talk at aps.anl.gov>
To: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Mark Rivers <rivers at cars.uchicago.edu>
Date: Tue, 4 Apr 2023 08:36:18 +0200
Hi Guys,
thank you for your help, I didnt have time to check them. But I definitly will.
What I can say now is that my ARC...dll is in the same location as yours, Mark. Root Dir of Lightfield.
If I run Lightfield directly, everything works as expected.
I'll try the dependency walker and see what it reports - maybe it helps understanding.
Thanks again,
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 29.03.23 um 15:07 schrieb Freddie Akeroyd - STFC UKRI via Tech-talk:
If you add the line
setlocal
to the top of  start_epics.bat   then changes to environment variables are not kept after the .bat file exits, so that should stop PATH growing too long
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: 28 March 2023 17:49
To: William Kirstaedter <kirstaedter at fhi-berlin.mpg.de>; tech-talk <tech-talk at aps.anl.gov>
Subject: RE: areadetector on windows, xml2 done, now Lightfield
Hi William,
I forgot to follow-up on one part of your message:
I also noticed that the ddlPath.bat clobbers the PATH with each IOC boot until windows complains that the PATH is too long.
(this of course only happens if you launch the .bat from commandline, if launched via double-click its fine)
I'd suggest a change in dllPath.bat:
dllPath.bat is automatically generated by the build system in EPICS base, so that is not something I can change in ADLightField.
I think the intention of the EPICS developers is that dllPath.bat is something you execute once per terminal session, not something you execute each time the IOC is started.
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Re: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
RE: areadetector on windows, xml2 done, now Lightfield Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Digital status mask? Paul Sichta via Tech-talk
Next: Re: Probe plug-in for the Probe panel? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: RE: areadetector on windows, xml2 done, now Lightfield Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
ANJ, 13 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
