1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: EPICS Qt 3.9.1 [SEC=OFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <[email protected]>
To: 'EPICS Tech-Talk' <[email protected]>
Date: Wed, 5 Apr 2023 05:35:51 +0000
Hi all,
The EPICS Qt 3.9.1 release is available at GitHub:
The source code is available from: https://github.com/qtepics with
general guidance/documentation available at:
https://qtepics.github.io and
the release notes are available here: https://qtepics.github.io/release_notes.html
All the repositories have been tagged r3.9.1  The main impact of this release is to
make the EPICS Qt  framework Qt6 compatible,please see the release notes for details.
The actual release to GitHub was last month (6th March). Since then I have decided
to totally replace the content of the example plugin repo. with a plugin containing
some real-world widgets that we actually use at the Australian Synchrotron, together
with some documentation.
Please note: these widgets are facility specific and are supplied as examples and for
inspiration only. If you intend to build this plugin as is, you will need the r3.9.1.1
qeframework tag – no release documentation for that yet, but the git log just about
covers it anyway.
 Have a great Easter.
Andrew C Starritt
Accelerator Controls and Support Systems
Tel
Email
Web
+61 3 8540 4164
[email protected]
www.ansto.gov.au
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
OFFICIALOFFICIAL
EPICS Qt 3.9.2 available [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Prev: Re: Probe plug-in for the Probe panel? Michael Davidsaver via Tech-talk
Next: Re: USPAS (was: RE: [External] Re: Probe plug-in for the Probe panel?) Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: epics css motor setup problem&question Mark Rivers via Tech-talk
Next: EPICS Qt 3.9.2 available [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
