1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Sending messages to Phoebus via Protobuf
Date: Thu, 6 Apr 2023 07:36:56 +0000
Hi Mihnea Romanovschi,
I would expect you might not be adding the right separation between events. The archiver uses new line separation.
The library phoebus uses internally is:
https://github.com/slacmshankar/epicsarchiverap_pbrawclient/tree/master
That might be useful for writing tests against.
Another useful library to look at is mdavidsaver’s aaclient which has an example protobuf file:
https://github.com/mdavidsaver/aaclient/tree/master/aaclient/test
I hope that helps.
Sky
______________________
 Software Engineer
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 22 26
E-mail: [email protected]
Prev: Re: base 7.0.7 build fails on RHEL7 Hartman, Steven via Tech-talk
Next: RE: base 7.0.7 build fails on RHEL7 Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Sending messages to Phoebus via Protobuf Mihnea Romanovschi - STFC UKRI via Tech-talk
Next: Digital status mask? William F Badgett Jr via Tech-talk
