1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: epics synapps asyn compile error
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, whitetiger1123 <holyeongbaeg at gmail.com>
Date: Thu, 13 Apr 2023 12:13:56 +0000
What version of Linux are you using?
What do you see when you run this command:
which rpcgen
On Centos7, which does not use tirpc, I see this:
corvette:lightFieldIOC/lightFieldApp/src>which rpcgen
/bin/rpcgen
On Ubuntu 20, which does use tiprc, I see this:
TahoeU18:~> which rpcgen
/usr/bin/rpcgen
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of whitetiger1123 via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, April 13, 2023 3:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: epics synapps asyn compile error
I’d like to compile epics synapps asyn package, it shows an error even I uncomment this line in configure/CONFIG_SITE : #TIRPC=YES,
And install libtirpc-devel(sudo yum install libtirpc-devel)
Error:
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/usr/local/epics/main/modules/synApps/support/asyn-R4-40/asyn/O.linux-x86_64'
make[1]: *** [/usr/local/epics/main/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps/support/asyn-R4-40/asyn'
make: *** [/usr/local/epics/main/base/configure/RULES_DIRS:85: asyn.install] Error 2
Do you know how can I compile asyn package without this error?
epics synapps asyn compile error whitetiger1123 via Tech-talk
Prev: Re: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Next: modbus ioc start Dale Cox via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: epics synapps asyn compile error whitetiger1123 via Tech-talk
Next: 'isegHAL' module / IOC for iseg device Gabriel Fedel via Tech-talk
ANJ, 13 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
