1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2)
From: whitetiger1123 via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 16 Apr 2023 11:53:30 +0900
I want to compile our motor submodule, but it shows compile error
I added RELEASE(path: /usr/local/epics/main/modules/synApps_6_1/support/motor-R7-1/modules/motorKk6k_old/iocs/KkIOC/configure) file like this:
  # RELEASE - Location of external support modules
   SUPPORT=/usr/local/epics/main/modules/synApps_6_1/support
   EPICS_BASE=/usr/local/epics/main/base-3.15.6
   AUTOSAVE=$(AUTOSAVE)/autosave-R5-10
# Use motor/module's generated release file when buidling inside motor
-include $(TOP)/../../../RELEASE.$(EPICS_HOST_ARCH).local
   # Use motorAcs's release file when building inside motorAcs, but outside motor
    -include $(TOP)/../../configure/RELEASE.local
    # Use acsIOC's RELEASE.local when building outside motorAcs
    -include $(TOP)/configure/RELEASE.local
And now, it shows me this error when I compile motorIOC(path: /usr/local/epics/main/modules/synApps_6_1/support/motor-R7-1/modules/motorKk6k_old/iocs/KkIOC/iocBoot) :
[root@localhost iocBoot]# make
EPICS/Release.pm: Circular definition of macro AUTOSAVE
make -C ./iocKk install
make[1]: Entering directory '/usr/local/epics/main/modules/synApps_6_1/support/motor-R7-1/modules/motorKk6k_old/iocs/KkIOC/iocBoot/iocKk'
perl -CSD /usr/local/epics/main/base-3.15.6/bin/linux-x86_64/convertRelease.pl -t /usr/local/epics/main/modules/synApps_6_1/support/motor-R7-1/modules/motorKk6k_old/iocs/KkIOC envPaths
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/motor-R7-1/modules/motorKk6k_old/iocs/KkIOC/iocBoot/iocKk'
make: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: iocKk.install] Error 2
this our motorKk6k_old submodule is same as other motor modules. I compiled other sub motor modules, but I don’t know why only this motor module can’t compile
Can you give me any solutions?
Sincerely,,
Baeg
Re: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) Mark Rivers via Tech-talk
Prev: areadetector compile error "X11/extensions/shae.h" no such file whitetiger1123 via Tech-talk
Next: Re: areadetector compile error "X11/extensions/shae.h" no such file Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: areadetector compile error "X11/extensions/shae.h" no such file Mark Rivers via Tech-talk
Next: Re: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) Mark Rivers via Tech-talk
ANJ, 16 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
