Hi folks,
I've just installed CentOS 9 stream on a new machine here, then added on epics-base, calc, asyn, and StreamDevice from git. I've also installed my work in progress for the Keysight 34980A mainframes, which speak SCPI. All the EPICS bits work, but there's something screwy with the firewall. When I do " $ pvget KS_34980A_EPICStestswitcherMagnetCurrent" it times out in 5 seconds. "$ caget KS_34980A_EPICStestswitcherMagnetCurrent" works just fine. I can turn the firewall off ($ sudo systemctl stop firewalld) and then pvget works fine. I added ports 5064 and 5065 in both TCP and UDP to the rules for the firewall, but that didn't seem to help.
Firewall rules:
$ sudo firewallcmd --list-all
[sudo] password for leblanc:
sudo: firewallcmd: command not found
[leblanc@epics1 ~]$ sudo firewall-cmd --list-all
public (active)
target: default
icmp-block-inversion: no
interfaces: enp1s0
sources:
services: cockpit dhcpv6-client ssh
ports: 5064/tcp 5065/tcp 5064/udp 5065/udp
protocols:
forward: yes
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules:
I also used ss to see what ports pvget was trying to use
$ ss -antup |grep pvget
udp UNCONN 0 0 0.0.0.0:45383 0.0.0.0:* users:(("pvget",pid=49094,fd=3))
udp UNCONN 0 0 224.0.0.128:5076 0.0.0.0:* users:(("pvget",pid=49094,fd=6))
udp UNCONN 0 0 10.0.255.255:5076 0.0.0.0:* users:(("pvget",pid=49094,fd=5))
udp UNCONN 0 0 10.0.0.239:5076 0.0.0.0:* users:(("pvget",pid=49094,fd=4))
I'm not sure what else to try at this point. Any pointers appreciated.
Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
leblanc at ohio.edu
M: (401) 52-OUAL1 or (401) 526-8251
- RE: PV access stopped by the firewall CentOS 9 Stream Žiga Oven via Tech-talk
RE: Is the Sequencer and SNL still widely used? Iain Marcuson via Tech-talk
RE: mbbo with 32 choices Pearson, Matthew via Tech-talk
<2023>
2025
Re: mbbo with 32 choices Maren Purves via Tech-talk
<2023>
2025
