Hi, all:
I am trying to set up a gateway(V2_1_3 with base3.15.9), and I find the pvlist file is not working. I can't find the PVs' ALIAS name. The gateway command is: ./gateway -sip 192.168.2.170 -cip "192.168.2.171:5064 192.168.2.172:5064 192.168.2.173:5064" -pvlt ./GATEWAY.pvlist -access ./GATEWAY.access -debug 1 -log gateway.log My pvlist is "GATEWAY.pvlist". It contains:
--------------------------------------------------------------------------------------------------------------------------------------------------------------------- EVALUATION ORDER ALLOW,DENY
[0-9].* ALLOW __________________________________________________________________________________________ I can access the PV test:OprRun
[TimeLjs@node1 Heartbeat-3-0-958e11be8686]$ caget test:OprRun but I can't access the PV test_gw:OprRun
[TimeLjs@node1 Heartbeat-3-0-958e11be8686]$ caget gateway:test:OprRun I think the command "^test ALIAS gateway:test" doesn't work.(I have installed Perl-5.36.0)
Does anyone have any idea what's going on? Any suggestion?
Thanks Jiaosai Li
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
