1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Does anyone have documented PV Access run time ENV variables?
From: Timo Korhonen via Tech-talk <[email protected]>
To: "Kim, Kuktae" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 3 May 2023 12:13:21 +0000
Hi Kuktae,
This is probably not what you are looking for, or at least not nearly the full story, but maybe helps:
https://github.com/epics-base/pvAccessCPP/wiki/protocol
Also, Michael Davidsaver has written documentation for PVXS:
https://mdavidsaver.github.io/pvxs/overview.html
This goes a bit more in the direction of user documentation.
And, partially, but not only because of this, we are preparing an EPICS Document-athon at ESS end of August (28.August – 1.September, 2023).
I will prepare an announcement – or first “save the date” kind of message – for that event as soon as I can figure out some details. But we have an OK for the event so it is going to happen.
Best regards,
Timo
From: Tech-talk <[email protected]> on behalf of "Kim, Kuktae via Tech-talk" <[email protected]>
Reply to: "Kim, Kuktae" <[email protected]>
Date: Wednesday, 3 May 2023 at 05:35
To: tech-talk <[email protected]>
Subject: Does anyone have documented PV Access run time ENV variables?
Hello everyone,
I am currently studying EPICS Channel Access (CA) and PV Access (PVAccess and PVXS), particularly the server/client-side environment variables used for run-time configuration. While researching, I came across very good documentation for EPICS CA, which can be found in the links below:
However, I am having difficult finding good documentation for PVA on the EPICS base site:
Although, I did find some information on the PVXS site thanks to Michael Davidsaver, I still feel that is not sufficient. Here is the link to the information I found:
Could someone please point me in the direction of a reference document that provides more comprehensive information on PVA?
Thank you very much for your help.
Best regards,
Kuktae
Re: [EXTERNAL] Does anyone have documented PV Access run time ENV variables? Hartman, Steven via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Andrew Johnson via Tech-talk
Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Prev: Bug in ADPICam driver found. Jörn Dreyer via Tech-talk
Next: Re: [EXTERNAL] Does anyone have documented PV Access run time ENV variables? Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
