1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Epics Archiver Online Status Question
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Tynan Ford <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 3 May 2023 18:49:07 +0000
That sounds like exactly what I need Tynan. Any chance I could take a peak of your implementation for the PV?
Thanks
Adam
On May 3, 2023, at 11:11 AM, Tynan Ford <[email protected]> wrote:
Hi Adam,
I don't know of a status PV associated with the archiver myself. We implemented a PV with a subroutine like you suggested. It queries an archiver appliance HTTP endpoint and determines if the archiver is up and running based on that.
For instance, you could check that mgmt/bpl/startupState, engine/bpl/startupState, etc. return "STARTUP_COMPLETE". Or query an endpoint like mgmt/bpl/getApplianceInfo and ensure it returns a valid response.
Best
Tynan
On Tue, May 2, 2023 at 1:11 PM Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Hi All,
Are there any PVs associated when you start up the Epic Archiver that you can read for status of the Archiver (Online, Running, Etc)?  If not does anyone have a simple solution to display in CSS GUI (LED or Text Box) that the archiver is in fact running, one thought was an ASUB record with some C written to check if the web interface of the archiver was reachable.
Adam
Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
Epics Archiver Online Status Question Manoussakis, Adamandios via Tech-talk
Prev: Re: EPICS support for the Omega Platinum Series PID Controllers Michael Davidsaver via Tech-talk
Next: Re: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
Next: Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
