1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Freeing allocated buffers in areaDetector HDF5 Plugin
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Wed, 3 May 2023 23:41:38 +0000
Hi, all!
Im doing some proof of concepts with areaDetector cloned directly from master (commit 78fae55898b9028e756eb080367cd6aad8913b54) and the plugins together with EPICS_BASE 7.
When using the HDF5 plugin and saving with the capture mode, documentation (https://areadetector.github.io/master/ADCore/NDPluginFile.html?highlight=allocate) tells me a buffer will be allocated in memory before saving occurs. Consequently, when allocated buffer is bigger than available memory, application freezes my machine.
The thing is: after the saving occurs, the buffer doesnt seem to be de-allocated. I say that because htop shows memory usage growing continuously when acquire is happening with capture mode on, but memory usage does not decrease once saving is done. I tried using the <PREFIX>FlushNow PV but i only get this error:
epics> dbpf 13SIM2:HDF1:FlushNow 1
DBF_STRING:         "Flush"
epics> 2023/05/03 20:35:02.845 NDFileHDF5:writeInt32: ERROR status=3, function=168, value=1 old=0
2023/05/03 20:35:02.845 13SIM2:HDF1:FlushNow devBusyAsyn::processCallbackOutput process error
epics>
epics>
epics>
DBF_STRING:         "Flush"
epics> 2023/05/03 20:35:34.577 NDFileHDF5:writeInt32: ERROR status=3, function=168, value=1 old=0
2023/05/03 20:35:34.577 13SIM2:HDF1:FlushNow devBusyAsyn::processCallbackOutput process error
Is this the correct usage of the PV? I also tried using <PREFIX>NumFramesFlush, but got no result.
Is there any recommended way i can de-allocate this buffer whenever i want? Until now, i need to restart the application every time i want my memory back.
Thanks in advance for any help,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Freeing allocated buffers in areaDetector HDF5 Plugin Mark Rivers via Tech-talk
Prev: Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
Next: Re: Freeing allocated buffers in areaDetector HDF5 Plugin Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Standard/clean way to copy NORD from one waveform to another (and aSub limitations) Érico Nogueira Rolim via Tech-talk
