1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: timestampField not retrieved using CA provider for pvac::ClientChannel
From: "Bisegni, Claudio via Tech-talk" <[email protected]>
To: "Veseli, Sinisa" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 May 2023 17:56:01 +0000
I tried to set request field as:
pvd::createRequest("field(value, timeStamp, alarm, display, control, valueAlarm)
but I didn’t get the timeStamp Field in PVStructure. The request field work well for all other (for CA provider) for the PVA provider, instead, I always got every field also if I put only “filed(value)” in the request.
I’m wrong somenting….
Claudio
Date: Friday, 5 May 2023 at 10:44
To: Veseli, Sinisa <[email protected]>, [email protected] <[email protected]>
Thank you for yor help, is effect on get operation I use the default request, so Iat this point I need to use pvd::createRequest("field(value, timeStamp, alarm, display, control, valueAlarm)")); to retrieve all field
I’ll give a try!
Thank you very much.
Claudio
Date: Friday, 5 May 2023 at 09:55
To: [email protected] <[email protected]>, Bisegni, Claudio <[email protected]>
I am not sure exactly why is there a difference in behavior between caget and pvget, but you should be able to get timestamps if you request them explicitly:
$ caget -a S01-DAQTBT:Strm:DataCaptureC
S01-DAQTBT:Strm:DataCaptureC   2023-05-03 10:51:26.834121 Off
PV request string like field(value,timeStamp) should work from C++:
>>> from pvapy import *
>>> c = Channel('S01-DAQTBT:Strm:DataCaptureC', CA)
>>> print(c.get('field(value,timeStamp)'))
epics:nt/NTEnum:1.0
    enum_t value
        int index 0
        string[] choices [Off, On]
    time_t timeStamp
        long secondsPastEpoch 1683129086
        int nanoseconds 834120910
        int userTag 0
Hope this helps,
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Bisegni, Claudio via Tech-talk <[email protected]>
Sent: Friday, May 5, 2023 11:39 AM
Subject: timestampField not retrieved using CA provider for pvac::ClientChannel
Hello EPICS tech,
I'm working with last epics release and I have notice that making a get operation for an IOC using a CA provider for crete a pvac::ClientChannel I don't receive the timestamp field:
I noticed that also the official caget has the problem:
developer@e058f4bc2090:/workspace$ pvget variable:sum
variable:sum 2023-05-05 16:34:54.607 3
developer@e058f4bc2090:/workspace$ caget variable:sum
variable:sum 3
so is a client library problem or a server or something else?
Thank
you in advance.
Claudio
Re: timestampField not retrieved using CA provider for pvac::ClientChannel Veseli, Sinisa via Tech-talk
timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Re: timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Prev: Re: timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Next: Re: timestampField not retrieved using CA provider for pvac::ClientChannel Veseli, Sinisa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
