1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: sequencer problem
Date: Wed, 10 May 2023 22:06:58 +0000
Folks,
I am seeing behavior I don’t understand with the sequencer.  I am using base 7.0.6.1 and sequencer 2.2.9 (latest).
I have a VxWorks IOC running a number of motors.  All of the motor records are loaded, but currently one of the motor controllers is not available, so that motor record is not functional.
I am running an SNL program on a Linux IOC,  and it connects to the motors on the VxWorks system, including the currently non-functional motor.  The SNL program puts monitors several of the motor record fields.
I see the following messages after iocInit when the SNL program starts:
seq BM13_Energy, "E=13BMA:E, MONO=13BMA:m17, EXPTAB_Z=13BMD:m22, YXTAL=13BMA:MON:, ZXTAL=13BMA:m14"
sevr=info Sequencer release 2.2.9, compiled Wed May 10 16:25:47 2023
sevr=info Spawning sequencer program "BM13_Energy", thread 0x2c304a0: "BM13_Energy"
sevr=minor BM13_Energy[0](after 0 sec): assigned=26, connected=26, monitored=24, got monitor=21
The SNL program has monitors on 3 record fields for the non-functional motor.  I think that is why there are 24 channels monitored, but only 21 monitors have been received?
The above seems like it might be normal.  However, after about 30 seconds I get this error on the Linux IOC:
CA.Client.Exception...............................................
    Warning: "Virtual circuit unresponsive"
    Context: "ioc13bma.cars.aps.anl.gov:5064"
    Source File: ../tcpiiu.cpp line 926
    Current Time: Wed May 10 2023 16:53:37.844955871
At the same time I get this error on the VxWorks IOC:
DB CA Link Exception: "Virtual circuit disconnect", context "corvette:38399"
After the exceptions I then get the following messages on the Linux IOC.   Note that it spontaneously dropped 24 of the 26 connections, and “got monitor” changed to -1.
sevr=minor BM13_Energy[0](after 0 sec): assigned=26, connected=2, monitored=24, got monitor=-1
Is this behavior expected?
RE: sequencer problem Mark Rivers via Tech-talk
Prev: Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
Next: RE: sequencer problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Change to dbRecordsOnceOnly? Andrew Johnson via Tech-talk
