1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Question about the best practice for integrating a stepper motor Python library into EPICS
To: Alexander Kessler <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 11 May 2023 15:10:18 +0000
When I said client/server I meant was Python opening the socket to the hardware, or listening for a socket connection from external software.  I see it is the former.
I think that porting to C++ will be a lot easier.  You only need to implement a few methods:  move(), moveVelocity(), stop(), home(), poll(), etc.  There are lots of example drivers to use as models.  We can help you find the one that is the closest match to your system so you have a good starting point.
The asynMotorController and asynMotorAxis base classes and the asyn device support take care of most of the details of interfacing to the motor record.
Sent: Thursday, May 11, 2023 9:46 AM
To: Mark Rivers; [email protected]
Hello Mark,
Yes, it is a TCP Connection to HW.
import socket
s = socket.socket()
timeout = 1.0
s.settimeout(timeout)
s.connect(host, port)
Well, it's a P2P connection, I think client-server is not the right term here. I would say Phyton Code is the master, says that to do it, and HW is the slave.
No EPICS so far. I'm trying to make a device driver IOC from Python Lib. Because I am complete beginner, I want to ask for the better way to do it. I see two options:
  1. port to C++
  2.  create in Python a PV interface according to the motor record. https://epics-modules.github.io/motor/motorRecord.html
    The module motorVMC seems to do something like this.
Best regards,
AlexK
Am 11.05.2023 um 14:30 schrieb Mark Rivers:
Hi Alex,
  • I have an in-house built stepper motor controller and a python library to control it.
  • It simply opens a TCP socket, sends a command bytecode and queries some state bytes.
Do you mean that the Python library opens a socket to the controller and sends a command bytecode and queries bytes from the hardware?
Or do you mean that external software (like EPICS) opens a socket to the Python library and sends a bytecode?
In other words is the Python library a socket server, or a socket client?
If the Python library is a socket client then how complex is it?  It might just be easier to replace it with a C++ asynMotorController that sends the bytecode and parses the response.
From: Tech-talk on behalf of Alexander Kessler via Tech-talk
Sent: Thursday, May 11, 2023 5:44 AM
To: [email protected]
Subject: Question about the best practice for integrating a stepper motor Python library into EPICS
Dear community,
to control it. It simply opens a TCP socket, sends a command bytecode
I would like to include the Python code in EPICS as my first productive
EPICS exercise. In C++, I would take EPICS engine module and create a
child class of asyncMotorControler.  But what is the best way to handle
it with Python? Is there an equivalent to C++ parent class on CAPROTO basis?
Thanks and best wishes,
AlexK
Alexander Kessler
Helmholtz-Institut-Jena
Fröbelstieg 3, 07743 Jena
phone:    +49-3641-947296
fax:      +49-3641-947299
email:    [email protected]
web:      http://www.rlp-ioq.uni-jena.de/
           http://www.hi-jena.de
Facility for Antiproton and Ion Research in Europe GmbH (FAIR GmbH) GSI Helmholtzzentrum für Schwerionenforschung GmbH Planckstraße 1, 64291 Darmstadt, Germany, www.fair-center.eu, www.gsi.de
Commercial Register / Handelsregister:
FAIR: Amtsgericht Darmstadt, HRB 89372
GSI: Amtsgericht Darmstadt, HRB 1528
Managing Directors / Geschäftsführung:
Professor Dr. Paolo Giubellino, Jörg Blaurock Chairman of the GSI Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
Ministerialdirigent Dr. Volkmar Dietz
Alexander Kessler
Prev: Re: Question about the best practice for integrating a stepper motor Python library into EPICS Alexander Kessler via Tech-talk
Next: cryomagnetics lm-500 Sinclair, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
