1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Why does libca.so depend on libreadline.so?
To: "Dmitry Yu. Bolkhovityanov" <[email protected]>, Andrew Johnson <[email protected]>, Simon Rose <[email protected]>
Date: Fri, 12 May 2023 14:23:20 +0000
I find that libCom does depend on libreadline for base 7.0.5, 7.0.6.1, and 7.0.7.
corvette:/usr/local/epics-devel>ldd base-7.0.5/lib/linux-x86_64/libCom.so
        linux-vdso.so.1 =>  (0x00007ffd3ed4d000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f654a0f4000)
        libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f6549eae000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f6549ca6000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f6549aa2000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f654979a000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f6549498000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f6549282000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f6548eb4000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f654a585000)
        libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f6548c8a000)
corvette:/usr/local/epics-devel>ldd base-7.0.6.1/lib/linux-x86_64/libCom.so
        linux-vdso.so.1 =>  (0x00007ffc4d5f2000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe375e9d000)
        libreadline.so.6 => /lib64/libreadline.so.6 (0x00007fe375c57000)
        librt.so.1 => /lib64/librt.so.1 (0x00007fe375a4f000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007fe37584b000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fe375543000)
        libm.so.6 => /lib64/libm.so.6 (0x00007fe375241000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fe37502b000)
        libc.so.6 => /lib64/libc.so.6 (0x00007fe374c5d000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fe37632d000)
        libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007fe374a33000)
corvette:/usr/local/epics-devel>ldd base-7.0.7/lib/linux-x86_64/libCom.so
        linux-vdso.so.1 =>  (0x00007ffd4d1f4000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f643e256000)
        libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f643e010000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f643de08000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f643dc04000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f643d8fc000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f643d5fa000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f643d3e4000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f643d016000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f643e6e6000)
        libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f643cdec000)
From: Tech-talk <[email protected]> on behalf of Simon Rose via Tech-talk <[email protected]>
Sent: Friday, May 12, 2023 9:09 AM
To: Dmitry Yu. Bolkhovityanov <[email protected]>; Andrew Johnson <[email protected]>
Cc: [email protected] <[email protected]>
Hi Dmitry -
I do not get the same results as you. When I build various version of EPICS base (e.g. 7.0.4, 7.0.5) for linux-x86_64, libCom also depends on readline at that point. I don't think the change that Michael linked is the source of this dependency.
Cheers,
Simon
On 2023-05-11, 11:09, "Tech-talk on behalf of Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi Andrew,
On Wed, 10 May 2023, Andrew Johnson wrote:
>> However, a brief investigation had found this had changed in the 7.0.x
>> between 7.0.2 and 7.0.7: in 7.0.2 the libca.so.4.13.3 does have a
>> dependency on libreadline, while 7.0.7's libca.so.4.14.2 does NOT.
>> So, if 7.0.x was refactored to get rid of this dependency, then this
>> change can probably be back-ported to 3.15.x. A quick inspection of
>> https://epics.anl.gov/base/R7-0/7-docs/RELEASE_NOTES.html <https://epics.anl.gov/base/R7-0/7-docs/RELEASE_NOTES.html> doesn't show any
>> traces of this change; probably a "diff -Naur" between sources is
>> required. I'm not sure my skills are sufficient for this back-porting,
>> but I'll try.
> I suspect that your brief investigation missed the fact that there were
> changes to the build system's detection of whether the target has a usable
> copy of readline installed, and those changes are almost certainly why some
> of your builds linked the libCom shared library with it and others didn't.
I performed checks on a same x86_64 system (CentOS7 with readline-devel
installed (specifically for EPICS3)), so the differences are caused by
7.0.x versions only.
BTW, I've just built all releases between 7.0.2.2 and 7.0.7 to find when
this change happened and it turned out to be the 7.0.7:
b360mc:/tmp/x% ldd base-7.0.6/lib/linux-x86_64/libCom.so.3.20.0 base-7.0.7/lib/linux-x86_64/libCom.so.3.22.0
base-7.0.6.1/lib/linux-x86_64/libCom.so.3.21.0:
linux-vdso.so.1 => (0x00007fffc3def000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f0b17fc5000)
libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f0b17d7f000)
librt.so.1 => /lib64/librt.so.1 (0x00007f0b17b77000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f0b17973000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f0b1766c000)
libm.so.6 => /lib64/libm.so.6 (0x00007f0b1736a000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f0b17154000)
libc.so.6 => /lib64/libc.so.6 (0x00007f0b16d87000)
/lib64/ld-linux-x86-64.so.2 (0x00007f0b18455000)
libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f0b16b5d000)
base-7.0.7/lib/linux-x86_64/libCom.so.3.22.0:
linux-vdso.so.1 => (0x00007ffe65529000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f402824d000)
librt.so.1 => /lib64/librt.so.1 (0x00007f4028045000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f4027e41000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f4027b3a000)
libm.so.6 => /lib64/libm.so.6 (0x00007f4027838000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f4027622000)
libc.so.6 => /lib64/libc.so.6 (0x00007f4027255000)
/lib64/ld-linux-x86-64.so.2 (0x00007f40286dd000)
The next step will be to find which git commit bringed this change.
> If you don't want your builds of libCom and libCa to depend on readline, you
> should ensure that it doesn't get built in by setting
> COMMANDLINE_LIBRARY=EPICS in an appropriate CONFIG_SITE* file.
Yes, I finally figured that out. 3.15.9 does include appropriate comments
in configure/os/CONFIG_SITE.Common.linux-x86_64; I wish those were present
in 3.15.6 days when I first met with readline problem, but there was only
a rather misleading "If none of them work, comment them all out to build
without readline support." statement, so I *had* to build libreadline
(which is a rather troublesome beast in itself) and adopted a strong
dislike of it :)
> Our default
> build configuration is likely to /always/ try to make use of readline if it's
> available, since it makes the IOC's shell so much easier to interact with.
> That is especially true now that the command-line completion features that
> readline provides have been integrated into iocsh.
Yes, that's understandable.
(I vividly remember the gulf in the convenience of editing the commandline
between bare-metal (be happy if Backspace works) and DOS, and later
between DOS and *NIX with Tab support.)
The only oddity which puzzled me is integration of commandline editing
into libCom -- that looks completely out of place.
With best regards,
Dmitry
Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Why does libca.so depend on libreadline.so? Michael Davidsaver via Tech-talk
Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
Re: Why does libca.so depend on libreadline.so? Simon Rose via Tech-talk
Prev: Re: Looking for a Water (LCW) Leak Sensor for machine interlock Daykin, Evan via Tech-talk
Next: Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Why does libca.so depend on libreadline.so? Simon Rose via Tech-talk
