1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Shutting down channel access clients
From: Maren Purves via Tech-talk <[email protected]>
Cc: [email protected]
Date: Thu, 18 May 2023 09:19:34 -1000
That is not my understanding of what Marco is trying to do.
My understanding is that Marco wants to shut down e.g. somebody's GUI, maybe because it takes up a port that is needed for something else.
Maren
On Thu, May 18, 2023 at 5:30 AM Andrew Johnson via Tech-talk <[email protected]> wrote:
(forgot to CC tech-talk).
Hi Marco,
I can think of 3 methods, depending on exactly what you're looking to do:
1. You can temporarily stop CA puts to an individual record by setting its DISP field to a non-zero value, DISP = Disable Put. When DISP is non-zero the server will only accept puts to the DISP field (so you can set it remotely and still re-enable puts again). This requires no preparation, but is per-record; the user may get an indication that puts are disabled when they try to modify a record field, internally this raises a S_db_putDisabled error which should get forwarded to the client but it might ignore.
2. You can temporarily stop CA writes to a group or records (or to all records) on a live IOC by loading an Access Security Configuration File that disables writes to that group (membership of which is controlled by the ASG field). The security rule can be controlled by a value obtained through CA, so you can easily turn write access off and on. If you're not used to access security this may involve some learning and experimentation to get working though; it requires a fair bit of preparation, but the user does get an indication from CA that they aren't permitted to write to the record fields when writes are disabled.
3. If you're able to reboot the IOC, you can set the environment variable EPICS_IOC_IGNORE_SERVERS to "rsrv" any time before iocInit or in the environment where the IOC is run, which will prevent the IOC's CA server from being started at all. This requires no preparation, applies to the whole IOC, and needs a reboot to enable/disable it; users won't know that the IOC is running at all when the server is being ignored.
Of course the same rules will apply to any other IOCs that link to the one you're working on. Using access security though you can set a different set of rules for the user and/or host that those IOCs are running as/on.
HTH,
- Andrew
On 5/18/23 9:50 AM, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hi, all!
Im used to seeing who is connected to an IOC via the command casr in the terminal. It works pretty well for me.
More than once i wanted to temporarily shut down a client from the IOC to better diagnose my system without external clients interfering in the process, but i still havent found a way to do this. Is there any command for that?
Thanks in advance for any help 🙂
Marco
Complexity is free, it's Simplicity that takes work.
Shutting down channel access clients Marco A. Barra Montevechi Filho via Tech-talk
Re: Shutting down channel access clients Andrew Johnson via Tech-talk
Prev: Re: Shutting down channel access clients Andrew Johnson via Tech-talk
Next: RE: Looking for a Water (LCW) Leak Sensor for machine interlock Guerrero, Christopher via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Question about Phoebus Rebecca Harding - STFC UKRI via Tech-talk
