1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: PVA Gateway Logging Problem
From: "Murray, Doug via Tech-talk" <[email protected]>
Date: Mon, 22 May 2023 18:16:20 +0000
I’ve successfully configured a PVA gateway (based on p4p R4.1.6) but I can’t get the logging mechanism to work.  The gateway itself is working fine.  I’ve reduced the config file to a simple one, but still no output is produced.
Does anybody have a working example of a JSON log config file in dictConfig format, or have an idea what might need to change in this file?
    "version": 1,
    "disable_existing_loggers": "False",
    "formatters": {
        "consoleFormat": {
            "format": "%(asctime)s | %(name)s | %(levelname)s | %(message)s"
    "handlers": {
        "consoleMessages": {
            "level": "DEBUG",
            "class": "logging.StreamHandler",
            "formatter": "consoleFormat",
            "stream": "ext://sys.stdout"
    "loggers": {
            "handlers": ["consoleMessages"],
            "level": "DEBUG",
            "propagate": "True"
cheers
-doug
Re: PVA Gateway Logging Problem Murray, Doug via Tech-talk
Prev: Re: makefile compilation question timesir via Tech-talk
Next: RE: no bin file Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Re:RE: no bin file Mark Rivers via Tech-talk
Next: Re: PVA Gateway Logging Problem Murray, Doug via Tech-talk
