I have previously installed the python opcua (actually opcua-asyncio) for the server simulation. The server creates the object MyObject with a member variable MyVariable.
The opcua-asyncio python client reads this as follows:
# Get the variable node for read / write
var = await client.nodes.root.get_child(
["0:Objects", f"{nsidx}:MyObject", f"{nsidx}:MyVariable"]
value = await var.read_value()
As suggested below, I tried
field( INP, "@opcua1 str:123,\"MyObject\".\"MyVariable\"" )
I also tried
field( INP, "@opcua1 str:123,\"MyObject.MyVariable\"" )
field( INP, "@opcua1 str:123,\'MyObject\'.\'MyVariable\'" )
field( INP, "@opcua1 str:123,\'MyObject.MyVariable\'" )
In every case, I get the error message from the IOC:
Error reading from node: BadNodeIdUnknown
In the server code, I can print the namespace index and node id which, for the above is 123 and 2 respectively.
Doing
field( INP, "@opcua1 num:123,2" )
does work and gets the correct value.
John
Am Freitag, 26. Mai 2023, 06:18:51 CEST schrieb Blomley, Edmund (IBPT) via
Tech-talk:
> Hey,
> > Saying:
> > field( INP, "@opcua1 str:123,MyObject.MyVariable" )
> > does not work but I could find nothing in the documentation that describes
> > the syntax for this case.
> I think you are missing quotation marks around the strings. For your case I
> would try:
> In general I find it helpful to use a OPC UA client to connect to the OPC
> server and look up the proper names of the relevant channels. For example
> this one:
https://urldefense.us/v2/url?u=https-3A__www.unified-2Dautomation.com_downloads_opc-2Dua-2Dclients.html&d=DwIFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=y1ySv2e6R1vXjM6-S-0q8nP52didqNXa2-iA6BX9G3w&m=jo1RgfpgortAIJVWuXWuI8DHNQ8N-IytVG--U3aloVKHHB650IhQAhzS0kLB_xzj&s=Apx5AxvkpcpVpVguN0iATlc-zoHyzlgDH5fRnexGdzk&e=
There is also a Python program called opcua-client that you can install via
pip.
Regards
Jörn
