1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Maxnet cant open omsAsyn no such file or directory
To: "[email protected]" <[email protected]>, Mayou Hasegawa <[email protected]>
Date: Tue, 30 May 2023 12:16:22 +0000
Hi Mayou,
You are building and running on the linux-x86_64 architecture.  However, the "ld" commands are only for vxWorks.  You just need to comment out the ld lines in your startup script.
From: Tech-talk <[email protected]> on behalf of Mayou Hasegawa via Tech-talk <[email protected]>
Sent: Monday, May 29, 2023 10:43 PM
To: [email protected] <[email protected]>
Subject: Maxnet cant open omsAsyn no such file or directory
Hi all,
I’m trying to build an IOC to talk to a MAXnet controller using synApps_6_1, motor_R7_1, motorOmsAsyn.
It booted very well and I can see EPICS IOC, when I start st.cmd file.
But the 1 problem is this IOC can’t recognize LL, LH at MAXnet.cmd. I think this problem is about can’t load omsAsyn.munch
This is the booting command:
[root@localhost iocOmsAsyn]# ./st.cmd
#!/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/bin/linux-x86_64/omsAsyn
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
#cd "/home/username/epics/iocs/omsAsynIOC/iocBoot/iocOmsAsyn"
< cdCommands
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("MOTOR","/usr/local/epics/synApps_6_1/support/motor-R7-1")
epicsEnvSet("SUPPORT","/usr/local/epics/synApps_6_1/support")
epicsEnvSet("ASYN","/usr/local/epics/synApps_6_1/support/asyn-R4-36")
epicsEnvSet("SNCSEQ","/usr/local/epics/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("BUSY","/usr/local/epics/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("AUTOSAVE","/usr/local/epics/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("OPTICS","/usr/local/epics/synApps_6_1/support/optics-R2-13-3")
epicsEnvSet("CALC","/usr/local/epics/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("STARUP","/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC")
epicsEnvSet("AUTOSAVE_PATH","/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave")
epicsEnvSet("AUTOSAVE_REQUEST","/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave-req")
#< ../nfsCommands
## You may have to change omsAsyn to something else
## everywhere it appears in this file
# 1) ld(0,0, "omsAsyn.munch")
  -> st.cmd line 12: Command ld not found.
# 2) ld 0,0, "omsAsyn.munch"
  -> st.cmd line 14: Command ld not found.
# 3) ld < omsAsyn.munch or omsAsyn
   -> st.cmd line 13: Can't open "omsAsyn.munch": No such file or directory.
dbLoadDatabase("/usr/local/epics/synApps_6_1/support/motor-R7-1/dbd/omsAsynSupport.dbd")
dbLoadDatabase("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/dbd/omsAsyn.dbd")
omsAsyn_registerRecordDeviceDriver(pdbbase)
## motorUtil (allstop & alldone)
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=TEST:")
< MAXnet.cmd
# Ethernet
#drvAsynIPPortConfigure("MAXNET1","10.4.135.90:4001",0,0,0)
#drvAsynIPPortConfigure("MAXNET1","10.4.47.118:2000",0,0,0)
# Serial
drvAsynSerialPortConfigure("MAXNET1","/dev/ttyUSB0",0,0,0)
asynSetOption("MAXNET1",0,"baud","115200")
asynSetOption("MAXNET1",0,"bits","8")
asynSetOption("MAXNET1",0,"parity","none")
asynSetOption("MAXNET1",0,"crtscts","Y")
# The IEOS depends on the firmware version
asynOctetSetInputEos("MAXNET1",0,"\n\r")
asynOctetSetInputEos("MAXNET1",0,"\n")
#asynOctetSetOutputEos("MAXNET1",0,"\n")
dbLoadTemplate("MAXnet.substitutions")
# omsMAXnetConfig(
# const char *portName, /* MAXnet Motor Asyn Port name */
# int numAxes, /* Number of axes this controller supports */
# const char *serialPortName,/* MAXnet Serial Asyn Port name */
# int movingPollPeriod, /* Time to poll (msec) when an axis is in motion */
# int idlePollPeriod, /* Time to poll (msec) when an axis is idle. 0 for no polling */
# const char *initString) /* Init String sent to card */
# Example init string:
# "AX LH PSO; AY LH PSO; AZ LH PSO; AT LH PSO; AU LH PSO; AV LH PSO; AR LH PSO; AS LH PSO;"
omsMAXnetConfig("MAXnet1", 10, "MAXNET1", 200, 2000, "AX LH PSO; AY LH PSO; AZ LH PSO; AT LH PSO; AU LH PSO; AV LL PSO; AR LH PSO; AS LH PSO; AW LH PSO; AK LH PSO;")
OMS Firmware Version: MAXn-A000 ver:1.50, s/n:000487, FPGA:AAA4:02 BOOT:1.06 - Oregon Micro Systems
#### Autosave save_restore start ####
#< save_restore.cmd
# Where to find the list of PVs to save
#set_requestfile_path("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave-req")
# Where to write the save files that will be used to restore
#set_savefile_path("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave")
# There files are the standard way to use autosave in synApps.
#set_pass0_restoreFile("auto_settings2.sav")
#set_pass1_restoreFile("auto_settings2.sav")
iocInit
Starting iocInit
## EPICS R3.15.9
## EPICS Base built Apr 7 2022
# Autosave monitor
#create_monitor_set("auto_settings2.req",60,"")
##### Autosave End ####
# Boot complete
epics>
I set ‘ld < omsAsyn.munch’ or omsAsyn, it can't open "omsAsyn.munch": No such file or directory.
omsAsyn bin file fath is ‘/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/bin/linux-x86_64’ here
and authority is
[root@localhost linux-x86_64]# ll
total 52
-r-xr-xr-x. 1 root root 50232 Apr 28 09:17 omsAsyn
Maxnet cant open omsAsyn no such file or directory Mayou Hasegawa via Tech-talk
Prev: Re: More precise timing for record processing Mark Rivers via Tech-talk
Next: Re: More precise timing for record processing Arnold, Ned D. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Maxnet cant open omsAsyn no such file or directory Mayou Hasegawa via Tech-talk
Next: procServ comminication with phoebus problem wang Ewen via Tech-talk
