Hi Mark ,
I can't run it properly .This the log:
[root@localhost ewen]# start_ioc ioc01
bash: start_ioc: command not found..
[root@localhost ewen]# python start_ioc ioc01
/usr/local/bin/procServ --logstamp -n "ioc01_IOC" -L /home/ewen/logs/ioc01.log 20008 /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd
/usr/local/bin/procServ: spawning daemon process: 7619
Trying ::1...
telnet: connect to address ::1: Connection refused
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
@@@ Welcome to procServ (procServ Process Server 2.9.0-dev)
@@@ Use ^X to kill the child, auto restart mode is ON, use ^T to toggle auto restart
@@@ procServ server PID: 7619
@@@ Server startup directory: /home/ewen
@@@ Child startup directory: /home/ewen
@@@ Child "ioc01_IOC" started as: /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd
@@@ Child log file: /home/ewen/logs/ioc01.log
@@@ Child "ioc01_IOC" is SHUT DOWN
@@@ procServ server started at: Fri Jun 2 16:18:07 2023
@@@ 0 user(s) and 0 logger(s) connected (plus you)
@@@ ^R or ^X restarts the child, ^Q quits the server
@@@ Restarting child "ioc01_IOC"
@@@ (as /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd)
@@@ The PID of new child "ioc01_IOC" is: 7621
/usr/local/bin/procServ: child could not execute: /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd, No such file or directory
@@@ Received a sigChild for process 7621. Normal exit status = 255
@@@ Current time: Fri Jun 2 16:18:08 2023
@@@ Child process is shutting down, a new one will be restarted shortly
@@@ The PID of new child "ioc01_IOC" is: 7631
[root@localhost ewen]# ps aux | grep procServ
root 7736 0.0 0.0 16928 1284 ? Ss 16:25 0:00 /usr/local/bin/procServ --logstamp -n ioc01_IOC -L /home/ewen/logs/ioc01.log 20008 /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd
root 7856 0.0 0.0 112816 972 pts/2 S+ 16:26 0:00 grep --color=auto procServ
This the IOCLIST set:
IOCLIST = """
ioc01 20008 1 /usr/local/EPICS/ioc01/iocBoot/iocmytest/st.cmd
iocs 20009 1 /usr/local/EPICS/ioc01/iocBoot/iocmyexample/st.cmd
# real iocs, terminal servers
#13LAB2 20041 1 /usr/bin/telnet gsets1.cars.aps.anl.gov 4002
#13IDE 20028 1 /usr/bin/telnet gsets1.cars.aps.anl.gov 4003
#13BMD 20026 1 /usr/bin/telnet gsets1.cars.aps.anl.gov 4004
# procServ command
#procserv = '/usr/local/bin/procServ -n "%s_IOC" --logstamp -L /home/epics/logs/%s.log %s %s'
procserv = '/usr/local/bin/procServ --logstamp -n "%s_IOC" -L /home/ewen/logs/%s.log %s %s'
I don't know where the problem is set,please help me check,Thank you .
Best regards,
Ewen
Hi Ewen,
- Thank you for your reply, it's working fine now. I want to run more than one iocs at the same times communication with css phoebus,is it the same port 5064? And just change the ioc name and port?
Yes, you normally always use the same CA port, 5064.
For procServ just change what script it executes to start the IOC, and the telnet port number.
Matt Newville wrote a nice Python script for starting our IOCs, which I have attached.
To add a new IOC you just added it to the IOCLIST. To start the IOC called 13BMD_XPS you just type
start_ioc 13BMD_XPS
That will also open a telnet connection to the correct port unless the “-s” or “–silent” option is used.
- Is it can autorestart when the server restart?
start_ioc takes a “-b” or “–onboot” flag in which case it starts all IOCs that are flagged to start on boot.
If the IOC is already running then typing
start_ioc 13BMD_XPS
will just telnet to the correct port.
Hi ,
Best regards,
Ewen
从 Windows 版邮件发送
You should be able to telnet to port 8888 to connect to the IOC shell via procServ.
