I start run annother ioc: [root@localhost iocmzexample]# procServ -n "my-ioc02" -L my-ioc.log -P 8889 -i "^D^C" /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd
procServ: spawning daemon process: 4394
[root@localhost iocmzexample]# ps aux | grep procServ
root 3258 0.0 0.0 16928 1272 ? Ss 06:09 0:00 procServ -n my-ioc -L my-ioc.log -P 8888 -i ^D^C /usr/local/EPICS/iocs/iocBoot/iocmyexample/st.cmd
root 4394 0.0 0.0 16928 1276 ? Ss 06:34 0:00 procServ -n my-ioc02 -L my-ioc.log -P 8889 -i ^D^C /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd
root 4444 0.0 0.0 112816 976 pts/2 S+ 06:34 0:00 grep --color=auto procServ.
This is the second ioc log:
@@@ Restarting child "my-ioc02"
@@@ (as /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd)
@@@ The PID of new child "my-ioc02" is: 4402
#!../../bin/linux-x86_64/mzexample
< envPaths
epicsEnvSet("IOC","iocmzexample")
epicsEnvSet("TOP","/usr/local/EPICS/ioc01")
epicsEnvSet("EPICS_BASE","/usr/local/EPICS/base")
cd "/usr/local/EPICS/ioc01"
dbLoadDatabase "dbd/mzexample.dbd"
mzexample_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/mzexampleVersion.db", "user=root"
dbLoadRecords "db/dbSubExample.db", "user=root"
#var mySubDebug 1
#traceIocInit
cd "/usr/local/EPICS/ioc01/iocBoot/iocmzexample"
iocInit
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Dec 16 2022
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 35429,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2023-06-02T06:34:42.607 Using dynamically assigned TCP port 56505.
## Start any sequence programs
#seq sncExample, "user=ewen"
[?1034hepics>
从 Windows 版邮件发送
You should be able to telnet to port 8888 to connect to the IOC shell via procServ.
