1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Keysight oscilloscope DSOX1204a connection issue
To: MuYuan Wang <[email protected]>
Cc: [email protected]
Date: Fri, 2 Jun 2023 16:33:48 -0700
This instrument supports both VXI-11 and Telnet style connections, I believe.    Have you tried both to see if the problem is limited to just one protocol?
On Jun 2, 2023, at 5:03 AM, MuYuan Wang via Tech-talk <[email protected]> wrote:
Hello All:
                Thanks for your kind help in advance.
                We have some Keysight oscilloscopes ready for running remotely (IOC by SCPI command), during the test we having disconnection issues happening from time to time, usually after running few days. From the panel which says cable disconnect and the only solution is to power cycle. So does anyone have the same problem as me and how to solve it. Thanks a lot.
Best Regards
MuYuan
Keysight oscilloscope DSOX1204a connection issue MuYuan Wang via Tech-talk
Prev: Re: [EXTERNAL] procServ comminication with phoebus problem Hu, Yong via Tech-talk
Next: how to use the GUN-RC-300 in mrfioc2 문건영(선형가속기팀) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Keysight oscilloscope DSOX1204a connection issue MuYuan Wang via Tech-talk
